Max Baud rate
Clemi
Max Baud rate
PostPosted: Mon Feb 23, 2009 6:59 pm     Reply with quote
what is the max. RS232 Baud rate I can run with a PIC 18F6723 (Hardware RS232) clocked with a 10MHz crystal? Is there a simple way to calculate this?
thanx Clemi
PostPosted: Mon Feb 23, 2009 11:01 pm     Reply with quote
Yes - it is in the data sheet from Microchip - check that.....
You can also Google around and find calculators on the Web - but I suggest that you figure it out from the data sheet - that way you will understand how the hardware works, which is very useful skill to have.
Also be sure to check the Errata on the part as the USART may have issues that are not on the data sheet.
HTH - Steve H.
PostPosted: Tue Feb 24, 2009 1:43 am     Reply with quote
See this thread about the Picbaud program:
http://www.ccsinfo.com/forum/viewtopic.php?t=37250
