Function Pointer BUG??
CristianC72
PostPosted: Tue Feb 17, 2009 10:24 am     Reply with quote
I must use function pointer but I have a several problem.
If I make a project with a single module es. 'main.c' all work, if I make a
project with multiple modules function pointer doesn't work.
This is the Working code with single module:
//MAIN.C
#include "main.h"
void Task1(void)
    printf("Start Task 1\r\n");
void Task2(void)
    printf("Start Task 2\r\n");
typedef void (*_fptr)(void);
    _fptr        fprt[2] = {Task1, Task2};
    for (;;)
      (*fprt[0])();
        (*fprt[1])();
// MAIN.H
#include <18F4685.H>
#FUSES NOWDT                     // No Watch Dog Timer
#FUSES WDT128                    // Watch Dog Timer uses 1:128 Postscale
#FUSES H4                        // High speed osc with HW enabled 4X PLL
#FUSES NOPROTECT                 // Code not protected from reading
#FUSES NOBROWNOUT                // No brownout reset
#FUSES BORV20                    // Brownout reset at 2.0V
#FUSES NOPUT                     // No Power Up Timer
#FUSES NOCPD                     // No EE protection
#FUSES NOSTVREN                    // Stack full/underflow will cause reset
#FUSES NODEBUG                   // No Debug mode for ICD
#FUSES NOLVP                       // Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                     // Program memory not write protected
#FUSES NOWRTD                    // Data EEPROM not write protected
#FUSES IESO                      // Internal External Switch Over mode enabled
#FUSES FCMEN                     // Fail-safe clock monitor enabled
#FUSES NOPBADEN                  // PORTB pins are configured as digital I/O on RESET
#FUSES NOWRTC                    // configuration not registers write protected
#FUSES NOWRTB                    // Boot block not write protected
#FUSES NOEBTR                    // Memory not protected from table reads
#FUSES NOEBTRB                   // Boot block not protected from table reads
#FUSES NOCPB                     // No Boot Block code protection
#FUSES LPT1OSC                   // Timer1 configured for low-power operation
#FUSES MCLR                      // Master Clear pin enabled
#FUSES NOXINST                   // Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock = 40000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
This is the result in the assembler file
....................     for (;;)
....................       (*fprt[0])();
000EE:  CLRF   FEA
000F0:  MOVLW  06
000F2:  MOVWF  FE9
000F4:  RCALL  004C     <----Call function
....................         (*fprt[1])();
000F6:  CLRF   FEA
000F8:  MOVLW  0A
000FA:  MOVWF  FE9
000FC:  RCALL  004C
....................         delay_ms(1000);
000FE:  MOVLW  04
00100:  MOVWF  0E
00102:  MOVLW  FA
00104:  MOVWF  0F
00106:  BRA    0086
00108:  DECFSZ 0E,F
0010A:  BRA    0102
0010C:  BRA    00EE
If I insert another file and now i compile with 2 module i have this assembler instruction
000E6:  CLRF   FEA
000E8:  MOVLW  06
000EA:  MOVWF  FE9 <----RCALL MISSED!!!!!!
00114:  CLRF   FEA
00116:  MOVLW  0A
00118:  MOVWF  FE9
00140:  MOVLW  04
00142:  MOVWF  0E
00144:  MOVLW  FA
00146:  MOVWF  0F
00148:  BRA    007C
0014A:  DECFSZ 0E,F
0014C:  BRA    0144
0014E:  BRA    00E6
PostPosted: Tue Feb 17, 2009 1:24 pm     Reply with quote
I don't think CCS officially says that function pointers work. I think they
work unofficially or as "beta". My suggestion is, if they don't work
with Multiple Compilation Units, then just use the "one big source file"
method.
PostPosted: Wed Feb 18, 2009 3:46 am     Reply with quote
Yes,
I have try this way and work, but I prefer have multiply modules
Txh
Cristian
