16F887 and serial LCD
Wohn
PostPosted: Thu Feb 12, 2009 8:52 pm     Reply with quote
I'm having a problem getting my LCD to work. NHD-0216K3Z-NSW-BBW and here is my code. Im just trying to get the backlight to turn on, and nothing is happening at all. Any help would be appreciated.
#include "16F887.h"
#use rs232(baud=9600, xmit=PIN_A0,invert, BITS=8, PARITY=N)
#fuses INTRC_IO,NOWDT,PUT,NOMCLR,NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,NOFCMEN,NOLVP,NOWRT,BORV40
   putc(0xFE);
   delay_ms(2);
   putc(0x53);
   delay_ms(2);
   putc(0x04);
Wohn
Solved
PostPosted: Fri Feb 13, 2009 10:36 am     Reply with quote
Well it seems that the default baud rate was not set on the LCD. I reset it by putting the LCD into i2c mode and that resets the baud.
