I want to test circuit about HID. How can I write code in CCS compiler ?
I try to use header file or example but it not working. Please help me.
I use 18f2550.
neungkub
Posted: Thu Feb 12, 2009 10:31 am
USB Device Not Recognized
this message form my computer . What's wrong my circuit or my code .
Rohit de Sa
Posted: Fri Feb 13, 2009 12:28 am
is usually a hardware problem. Check to see if you have the right valued capacitance on pin Vusb. Also check that the D+ and D- wires are not swapped.
