nicotec
gets to be verified |
Posted: Wed Feb 11, 2009 11:52 am |
Please could someone check why the following gets not appear to work properly?
Code: | #include <24FJ16GA002.h>
#include <string.h>
#FUSES NOJTAG //JTAG disabled
#FUSES ICS3 //ICD communication channel 3
#FUSES IOL1WAY //Allows only one reconfiguration of peripheral pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES FRC //Internal Fast RC Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is general purpose output
#FUSES NOPR //Primary oscillaotr disabled
#FUSES I2C1SELD
#use delay(clock=8000000)
#pin_select OC1=PIN_B0 //OUTPUT OF PWM PIN 4
#pin_select OC2=PIN_B1 //OUTPUT OF PWM PIN 5
#pin_select U1TX=PIN_B10 //RS-232 TX PIN 21
#pin_select U1RX=PIN_B11 //RS-232 RX PIN 22
#use rs232(UART1,baud=9600,parity=N,bits=8,stop=1)
#BYTE U1RXREG = 0x226
char cmd_board[12];
#int_rda
void Serial_isr()
gets(cmd_board);
output_high(PIN_B7);
long an_1;
long an_2;
long an_3;
setup_spi(SPI_SS_DISABLED);
setup_spi2(SPI_SS_DISABLED);
setup_wdt(WDT_ON);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
enable_interrupts(INT_RDA);
enable_interrupts(intr_global);
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,10000 );
setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
setup_compare(2,COMPARE_PWM | COMPARE_TIMER2 );
setup_adc_ports( sAN9 | sAN10 | sAN11 );
setup_adc(ADC_CLOCK_INTERNAL );
set_pwm_duty(1,1000); // 2ms on status
set_pwm_duty(2,1000); // 2ms on status
output_low(PIN_B8); //common pin for led
output_low(PIN_B6); //led off
output_low(PIN_B7); //led off
do
set_adc_channel( 9 );
an_1 = read_adc();
set_adc_channel( 10 );
an_2 = read_adc();
set_adc_channel( 11 );
an_3 = read_adc();
output_high(PIN_B6);
printf("%Lu%c%Lu%c%Lu%c%c",an_1,10,an_2,10,an_3,10,13);
printf("%s", cmd_board); // Display string receieved
} while(true);
rnielsen
Posted: Wed Feb 11, 2009 12:09 pm |
You're not using your int_rda() quite right. gets() will wait until a 'return' is detected. The best way to set things up is to use getc() to capture one character at a time, stuff each character in a buffer array and then when a character, like 'return', is detected set a flag and have the array manipulated some how in the main body of your code.
ISRs are meant to be short and sweet, detect that a character has entered the receive buffer, enter the ISR, put the character some where and get out so your PIC can be doing other things while it waits for the next character to show up.
With using gets() your PIC will stay inside the ISR until a 'return' is seen which will kill all other functions you might want to be doing. Use getc() and see how it works.
Plus, you should have placed this post in your original thread instead of starting a new one.
Ronald |
nicotec
Posted: Wed Feb 11, 2009 12:25 pm |
Thanks but I send only command like "55,61" or similar always followed by LF and CR using visual basic; do you think it works correctly?
Thanks |
