sliders_alpha
issue with array |
Posted: Sun Feb 08, 2009 8:40 am |
hello,
i must display time on a graphical LCD so o created big font.
i have a array wich is 800 long.
and why when i want to read array[256] my array is returning me array[0], or when i want to read array[257] i get array[1]
256,257, etc are stored in a "long" variable
this is my array :
const int8 font20x32[] = {
0x00,0x80,0xE0,0xF0,0xF8,0xF8,0xFC,0xFC,0x7E,0x3E,0x3E,0x7E,0xFC,0xFC,0xF8,0xF8,0xF0,0xE0,0x80,0x00, //0-1
0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x01,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00, //0-2
0x00,0x0F,0x3F,0x7F,0xFF,0xFF,0xFF,0xFC,0xF0,0xE0,0xE0,0xF0,0xFC,0xFF,0xFF,0xFF,0x7F,0x3F,0x0F,0x00, //0-3
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x03,0x03,0x03,0x03,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00, //0-4
0x00,0x00,0x80,0xC0,0xE0,0xE0,0xE0,0xF0,0xF8,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0x00,0x00,0x00,0x00,0x00, //1-1
0x00,0x00,0x0F,0x0F,0x07,0x07,0x02,0x02,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00, //1-2
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00, //1-3
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03,0x00,0x00,0x00,0x00,0x00, //1-4
0x00,0xC0,0xE0,0xF0,0xF8,0xF8,0xFC,0xFC,0x7E,0x3E,0x3E,0x3E,0xFE,0xFC,0xFC,0xF8,0xF8,0xF0,0xE0,0x00, //2-1
0x00,0x01,0x03,0x07,0x07,0x07,0x87,0x83,0xC0,0xE0,0xF0,0xF8,0xFE,0xFF,0xFF,0x7F,0x7F,0x3F,0x1F,0x00, //2-2
0x00,0xC0,0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xF3,0xF3,0xF1,0xF0,0xF0,0xF0,0xF0,0xF0,0x00, //2-3
0x00,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x00, //2-3
0x00,0xC0,0xE0,0xF0,0xF8,0xF8,0xFC,0xFC,0x3E,0x3E,0x3E,0x7E,0xFC,0xFC,0xF8,0xF8,0xF0,0xE0,0x80,0x00, //3-1
0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x30,0x78,0x78,0x78,0x7E,0xFF,0xFF,0xFF,0xFF,0xEF,0xC7,0x01,0x00, //3-2
0x00,0x18,0x38,0x7C,0xFC,0xFC,0xFC,0xF8,0xF0,0xE0,0xE0,0xE0,0xF0,0xFF,0xFF,0xFF,0xFF,0xEF,0x0F,0x00, //3-3
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x03,0x03,0x03,0x03,0x03,0x01,0x01,0x00,0x00,0x00,0x00,0x00, //3-4
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFE,0xFE,0x00,0x00,0x00, //4-1
0x00,0x80,0xE0,0xF0,0xF8,0xFC,0x7E,0x3F,0x1F,0x0F,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00, //4-2
0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0x0F,0x00, //4-3
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03,0x00,0x00,0x00, //4-4
0x00,0x00,0xC0,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x00, //5-1
0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x1C,0x1E,0x1E,0x1E,0x7E,0xFE,0xFE,0xFC,0xFC,0xF8,0xC0,0x00, //5-2
0x00,0x18,0x7C,0x7C,0xFC,0xFC,0xFC,0xF8,0xF0,0xE0,0xE0,0xE0,0xF8,0xFF,0xFF,0xFF,0x7F,0x3F,0x0F,0x00, //5-3
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x03,0x03,0x03,0x03,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00, //5-4
0x00,0x00,0xC0,0xE0,0xF0,0xF8,0xF8,0xFC,0x7C,0x3E,0x3E,0x3E,0xFE,0xFC,0xFC,0xF8,0xF8,0xF0,0x60,0x00, //6-1
0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x78,0x3C,0x3C,0x3C,0x7C,0xF8,0xF9,0xF9,0xF9,0xF0,0xC0,0x00, //6-2
0x00,0x07,0x1F,0x7F,0x7F,0xFF,0xFF,0xFF,0xF0,0xE0,0xE0,0xE0,0xF0,0xFF,0xFF,0xFF,0xFF,0x7F,0x1F,0x00, //6-3
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x03,0x03,0x03,0x03,0x01,0x01,0x00,0x00,0x00,0x00,0x00, //6-1
0x00,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0x7C,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0x7C,0x00, //7-1
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,0xF8,0xFE,0xFF,0xFF,0x7F,0x1F,0x07,0x03,0x00,0x00,0x00, //7-2
0x00,0x00,0x00,0x00,0x00,0xF0,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xF3,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //7-3
0x00,0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //7-4
0x00,0xC0,0xE0,0xF0,0xF8,0xF8,0xFC,0xFC,0x7E,0x3E,0x3E,0x3E,0x7E,0xFC,0xFC,0xF8,0xF0,0xE0,0xC0,0x00, //8-1
0x00,0xC1,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,0x7E,0x3C,0x3C,0x7C,0xFE,0xFF,0xFF,0xFF,0xFF,0xE7,0xC1,0x00, //8-2
0x00,0x1F,0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xF0,0xE0,0xE0,0xF0,0xF8,0xFF,0xFF,0xFF,0xFF,0x7F,0x3F,0x00, //8-3
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x03,0x03,0x03,0x03,0x03,0x01,0x01,0x00,0x00,0x00,0x00,0x00, //8-4
0x00,0xC0,0xF0,0xF0,0xF8,0xF8,0xFC,0x7C,0x3E,0x3E,0x3E,0x7E,0xFC,0xFC,0xF8,0xF8,0xF0,0xE0,0x80,0x00, //9-1
0x00,0x3F,0x7F,0xFF,0xFF,0xFF,0xF8,0xF0,0xE0,0xE0,0xE0,0xF0,0x78,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00, //9-2
0x00,0x10,0x78,0x7C,0xFC,0xF9,0xF9,0xF9,0xF1,0xE1,0xE1,0xF0,0xFC,0xFF,0xFF,0xFF,0x7F,0x3F,0x0f,0x00, //9-3
0x00,0x00,0x00,0x00,0x01,0x01,0x03,0x03,0x03,0x03,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 //9-4
and here is how i tried to read my array :
#include <16F877A.H>
#use delay(clock = 20000000)
#include <font20x32.c>
#DEFINE DB0 PIN_D0
#DEFINE DB1 PIN_D1
#DEFINE DB2 PIN_D2
#DEFINE DB3 PIN_D3
#DEFINE DB4 PIN_D4
#DEFINE DB5 PIN_D5
#DEFINE DB6 PIN_D6
#DEFINE DB7 PIN_D7
#DEFINE E PIN_E2
#DEFINE RW PIN_E1
#DEFINE RS PIN_E0
void put_data(int8 data) //
output_bit(DB0, !!(data & 1)); //decomposition d'un octet
output_bit(DB1, !!(data & 2)); //a envoyer et placement
output_bit(DB2, !!(data & 4)); //dur DB0 a DB7
output_bit(DB3, !!(data & 8)); //
output_bit(DB4, !!(data & 16)); //
output_bit(DB5, !!(data & 32)); //
output_bit(DB6, !!(data & 64)); //
output_bit(DB7, !!(data & 128)); //
delay_cycles(10); //
void enable(void) //validation
output_low(E); //
delay_cycles(50); //
output_high(E); //creer une impulsion sur E
output_low(E); //
void main(void) {
long l;
l = 240;
while(l<321)
put_data(font20x32[l]);
enable();
delay_ms(1);
l++;
here is what i get :
do any of you know why i can't acces data wich are stored futher than 255?
thanks
CCS V4.057[/img] _________________ yup, i know, i don't speak english very well
CCS V4.057
Last edited by sliders_alpha on Sun Feb 08, 2009 10:35 am; edited 1 time in total |
