How do I specify the upper 8 bit of the 16 bit field
Posted: Fri Feb 06, 2009 12:03 pm
Hi all,
I am using PCWHD Version 4.073
I want to save a 16 bit address in the eeprom of a 18F2520. I understand write_eeprom(address, value) will write an 8 bit value at the address. How do I specify the upper 8 bit of the 16 bit field and then the lower 8 bits?
See my post in this thread. It has routines to save a word to eeprom.
This example is for external eeprom, but you can change it to use
internal eeprom by removing the word "ext_" from the function names.
http://www.ccsinfo.com/forum/viewtopic.php?t=27405
