// Copyright (c) DVSoft 2004
// email dvsoft@club-internet.fr
// This program is free software; you can redistribute it and/or modify it
// under the terms of the GNU General Public License as published by the
// Free Software Foundation.
// This program is distributed in the hope it will be useful, but WITHOUT
// ANY WARRANTY; without even the implied warranty of MERCHANDIBILITY or
// FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
// more details.
// Originale Unit Name : DTFDriver.c
// Author : Alain
// Date : 15-Avril-2004
// Project : YA1-LOGGER-V3
// Version : 0.9.0.1
// Revision :
// DataFlash Driver AT45DB321B for CCS compiler
// Inactive Clock Polarity High
// level convertor 74F07 Hex inverter/buffer drivers (open-collector)
// Pull-Up resistor 2K2
// PIC18F452 TQFP AT45DB321B
// RC5 (SDO) -> DTF SI (15)
// RC4 (SDI) <- DTF SO (16)
// RC3 (SCK) -> DTF SCK (14)
// RE2 (/CS) -> DTF /CS (13)
// RE1 (WR) <- DTF RDY/BUSY (1)
// DTF /RESET +3.3V
// DTF /WP +3.3V
// Conditional code for the dataflash state in eeprom
#ifndef __DTF_DATA_STORAGE__
// ROM Space free
#define PROGRAM_MEMORY_SIZE getenv("PROGRAM_MEMORY")
#define FLASH_ERASE_SIZE getenv("FLASH_ERASE_SIZE")
#define BUFFER_END PROGRAM_MEMORY_SIZE-1
#define BUFFER_START (PROGRAM_MEMORY_SIZE-(FLASH_ERASE_SIZE*2))
// Config ROM Space (Application not for DataFlash)
#define CFG_BUFFER_START BUFFER_START
#define CFG_BUFFER_LEN CFG_BUFFER_START+0x000E
// DataFlash ROM Space
#define DTF_BUFFER_START (CFG_BUFFER_START+FLASH_ERASE_SIZE)
#define DTF_BUFFER_LEN (DTF_BUFFER_START+0x000E)
// Rom Configuration
#org CFG_BUFFER_START, CFG_BUFFER_LEN {}
// DTPageCnt in ROM
#org DTF_BUFFER_START, DTF_BUFFER_LEN {}
// DataFlash PageCnt in ROM Space
int16 DTFPageCntRomAddress;
// DataFlash Driver State
BOOLEAN DTFDriverRun;
// Function : DTFReadStatus(void)
// Input :
// void
// return :
// int The Status register value
// Modify :
// void
// Note :
#separate
int8 DTFReadStatus(void)
int8 Status;
//--- Select
DTFSelect();
//--- Command Read Status
spi_write(0x57);
//--- Status Result
Status = spi_read(0);
//--- Unselect
DTFUnSelect();
return (Status);
// Function : DTFPageToRam(int16 PageNum)
// Input :
// int16 PageNum Page index to load in memory buffer
// return :
// void
// Modify :
// Load the memory page 'PageNum' in current buffer (1 or 2)
// Note :
// Change the active buffer1 or Buffer2
#separate
void DTFPageToRam(int16 PageNum)
//--- Active buffer to main memory page
DTFAddress = (PageNum << 2);
while (!DTFIsReady());
//--- Select
DTFSelect();
//--- Buffer 2 is Active Buffer
if (DTF_Buffer_2_Active) {
//--- Memory Page To Buffer 1
spi_write(0x53);
//--- Set Buffer 1 Active
DTF_Buffer_2_Active = FALSE;
}// End IF
//--- Buffer 1 is Active Buffer
else {
//--- Memory Page To Buffer 2
spi_write(0x55);
//--- Set Buffer 2 Active
DTF_Buffer_2_Active = TRUE;
}// End Else
//--- 7 high address bits
spi_write(DTFAddress_H);
//--- 6 low address bits
spi_write(DTFAddress_L);
//--- don't care 8 bits
spi_write(0x00);
//--- Unselect
DTFUnSelect();
// Function : DTFRAMToPage(int16 PageNum)
// Input :
// int16 PageNum Page index to store
// return :
// void
// Modify :
// Store the current memory buffer in memory page 'PageNum'
// Note :
#separate
void DTFRAMToPage(int16 PageNum)
//--- Wait DTF_Ready
//--- Select
DTFSelect();
//--- Use Buffer 2 ?
//--- Buffer 2 To PAGE With Built In erase
spi_write(0x86);
}// End IF
else {
//--- Buffer 1 To PAGE With Built In erase
spi_write(0x83);
}// End ELse
spi_write(0x00);
//--- Unselect
DTFUnSelect();
// Function : DTFInitDump(void)
// Input :
// void
// return :
// void
// Modify :
// Set the dataflash page dump 'DTFDumpPageCnt' to 0
// Load the first memory page in memory buffer
// Note :
#separate
void DTFInitDump(void)
//--- First page to dump
DTFDumpPageCnt = 0;
//--- Load first page in memory buffer
DTFPageToRam(DTFDumpPageCnt);
#separate
// Function : DTFDumpPacket(void)
// Input :
// void
// return :
// int 0 End off memory pages
// 1 Some memory pages left
// Modify :
// increment the dataflash page dump 'DTFDumpPageCnt'
// Note :
// Load in memory buffer the next memory page
int DTFDumpNextPage(void)
//--- Next Page
DTFDumpPageCnt++;
//--- Not in Last Page ?
if (DTFDumpPageCnt < DTFPageCnt) {
//--- Load in memory buffer
//--- OK
return 1;
}// End If
//--- Fin
return 0;
// Input :
// void
// return :
// void
// Modify :
// void
// Note :
// Dump the complet buffer to the serial UART
// Send only the data in Dataflash buffer
#separate
void DTFDumpPacket(void)
int8 TxBuffer;
int16 ByteCnt;
//--- Initialisation
DTFSelect();
//--- Buffer 2 is Active ?
spi_write(0x56);
spi_write(0x54);
//--- 8 Dont'care Byte
spi_write(0x00);
//--- High Byte address
spi_write(0x00);
//--- Low Byte address
spi_write(0x00);
spi_write(0x00);
//--- Byte Count
ByteCnt = DTFPageSize;
//--- Load In Buffer
do {
//--- Read One Byte
TxBuffer = spi_read(0);
//--- Put in serial UART
putc(TxBuffer);
} while (--ByteCnt);
//--- Unselect
DTFUnSelect();
// Function : DTFOpen(void)
// Input :
// void
// return :
// void
// Modify :
// Set the flag 'DTFDriverRun' to TRUE if ok
// FALSE if not Ok
// Set the Flag 'DTFFull' to TRUE if (DTFPageCnt == DTFNbrPage)
// Set the Byte Count 'DTFByteCnt' to 0
// Set the Dump page counter 'DTFDumpPageCnt' to 0
// Note :
#separate
void DTFOpen(void)
int8 Status;
//--- Setup du SPI
setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END);
//--- Buffer 1 Is Active Buffer
//--- Read the status register
DTFReadStatus();
//--- Read 2 just in case
Status = DTFReadStatus();
//--- Status OK ?
// AT45DB321B (TABLE 4 and 5 page 8) Using Atmel's DataFlash document
// bit 7 bit6 bit5 bit4 bit3 bit2 bit1 bit0
// Rdy/Busy Compare Density code reserved
// 1 0 1 1 0 1 0 0
if (Status & 0x80) {
//--- i store the lastpage value in eeprom area
// so you must provide this data
DTFFull = (DTFPageCnt == DTFNbrPage);
//--- First Word
DTFByteCnt = 0;
//--- Dump page Count
DTFDumpPageCnt = 0;
//--- DataFlash OK
DTFDriverRun = TRUE;
}// End If
//--- DataFlash HS ?
DTFDriverRun = FALSE;
// Function : DTFWriteToFlash(int8 Data)
// Input :
// int8 Data Data to flash
// return :
// void
// Modify :
// Set the flag DTFFul if last page
// Note :
// Automatique store to memory area with built-in-erase when the ram buffer
// is full. Use double bufferring for fast operation
#separate
void DTFWriteToFlash(int8 Data)
//--- Drivers RUN ?
if (!DTFDriverRun)
return;
//--- DTF Full
if (DTFFull)
return;
//--- Wait Ready
//--- Start Write Ram
DTFSelect();
//--- Write To Buffer 1 ?
spi_write(0x87);
//--- Write to Buffer 2
spi_write(0x84);
//--- 8 Don't care Bit
spi_write(0x00);
spi_write(DTFByteCnt_H);
spi_write(DTFByteCnt_L);
//--- Write The Value
spi_write(Data);
//--- UnSelect
DTFUnSelect();
//--- Next Word Address In DataFlash
DTFByteCnt++;
//--- Last page Byte ?
if (DTFByteCnt >= DTFPageSize) {
//--- WriteRam Start Addresse
DTFByteCnt = 0;
//--- RAM To Memory page with builtin erase
DTFRAMToPage(DTFPageCnt);
//--- Next Page
DTFPageCnt++;
//--- Store the Last Page Value in PIC eeprom
erase_program_eeprom(DTFPageCntRomAddress);
write_program_eeprom(DTFPageCntRomAddress,DTFPageCnt);
//--- Last Page ?
if (DTFPageCnt >= DTFNbrPage)
DTFFull = TRUE;
}// End IF
alain
sumi
I really need help!!!
Posted: Sun Jul 27, 2008 10:22 pm
Hi dvsoft. I'm sumi and i'm studying in polytechnic now. I'm supposed to write a program about AT45DB321D driver for PIC18f4520. I have found urs. But u r using CCS complier. I'm using MCC18 complier. So i'm trying to edit it but still a lot of problems. So plz can u help me to edit it for MCC 18 complier? I need it urgently for my major project. Thankz....
