I am using the ICD-U (USB version) and the new 12F675 demo board from CCS. I know that the host (demo board) provides power to the ICD but the linear regulator on the demo board get quite hot (40C above ambient measured at the TO-220 tab). Does anyone know the current draw of the ICD? FYI the linear regulator stays about the same temp with the USB cable detached.
VB
___________________________
Original Post ID: 13478
Warren Massey Guest
Re: Current Draw of the ICD-U
Posted: Tue Apr 08, 2003 12:57 pm
:=I am using the ICD-U (USB version) and the new 12F675 demo board from CCS. I know that the host (demo board) provides power to the ICD but the linear regulator on the demo board get quite hot (40C above ambient measured at the TO-220 tab). Does anyone know the current draw of the ICD? FYI the linear regulator stays about the same temp with the USB cable detached.
:=VB
Original Post ID: 13508
Warren Massey Guest
Posted: Tue Apr 08, 2003 1:05 pm
:=VB
Here's an old thread that included a discussion of the hot regulator:
I've added a heatsink to the regulator and I'm now using an Astrodyne SPU15A-3 12V power supply ( <a href="http://www.astrodyne.com/astro/pdf/DSKT.pdf" TARGET="_blank">http://www.astrodyne.com/astro/pdf/DSKT.pdf</a>)
and it helps a bit but it still does get hot. It's a poor design IMHO.
Original Post ID: 13509
