I2C code
Spaark
I2C code
PostPosted: Wed Apr 09, 2003 2:24 pm     Reply with quote
Is there a possibility to see the code that is executed when the command I2C_write() and I2C_read() is called?
___________________________
Original Post ID: 13555
Re: I2C code
PostPosted: Wed Apr 09, 2003 2:35 pm     Reply with quote
:=Is there a possibility to see the code that is executed when the command I2C_write() and I2C_read() is called?
Yes. When you compile a file such as TEST.C, the compiler
makes a file called TEST.LST that contains the assembly
language code. Just use MPLAB to look at it.
Original Post ID: 13556
