Dallas 1wire using the DS2482 I2C to 1-wire chip
MikeW
PostPosted: Tue Feb 03, 2009 7:05 am     Reply with quote
Has anyone got this device to work ?
I am tearing my hair out on this.
I know my I2C bus is working, since I have other devices on the bus.
I have had to go back to software I2C to use it ( the hardware I2C works fine with other devices).
I am using the Dallas AN3684 software routines, and cant get the OWSearch to find any 1wire devices.
my 1wire DS18B20's work fine using the 1 wire bit-banged routines.
maybe I am trying to be too clever in off-loading the DOW protocol
Mike
herselmann
PostPosted: Tue Feb 03, 2009 7:44 am     Reply with quote
Which one? There are two different ones. I have sampled some just last week but don't know when i will have a chance to play with them and thus be able to give you advice.
I would start by testing the search code with a bit-bang interface. From what I have read from the datasheet, you should be able to replace the bottom 'layer' with the i2c bridge master chip at a latter stage leaving all the other functions the same.
That being said, from what I can remember from the command table in the datasheet, it seemed like the chip has some commands specific to the search function.
Did you remember your Pull-ups?
I recall something about two's compliment when writing to some registers, but might be confusing this with other datasheets...
If the manufacturer has to dedicate a whole app note to a device then it must mean that it is more difficult that expected...
Here is a link for AVR code:
http://www.koders.com/c/fid9F966AF5A29CD2065933ED960EF0CEDC16DE5A96.aspx
EDIT: This might also help: http://www.ccsinfo.com/forum/viewtopic.php?p=64807
There are only 10 kinds of people, those who understand binary and those who don't.
MikeW
PostPosted: Tue Feb 03, 2009 9:00 am     Reply with quote
DS2482-100, the single channel device.
I can talk to the I2C part of the DS2482.
I have all necessary pullups.
I am having problems with the find devices routines,.... it cant find any.
re two's complement, I think you mean that the config register only uses the bottom 4 bits, but the top 4 bits must be written as the complement., ie 0x0F, or 0x1E
seems very strange.
my 1wire bit banging routines work a treat.
since I dont have a pic io pin connected to the 1wire bus, it is not simple to do a search rom using bit banging.
time for wire and a soldering iron methinks.
the AVR routines dont have a find rom function implemented
Mike
MikeW
progress, and things to try
PostPosted: Tue Feb 03, 2009 9:11 am     Reply with quote
the AVR routines look promising, I will keep you updated
Mike
MikeW
further info to help me
PostPosted: Tue Feb 03, 2009 9:28 am     Reply with quote
this looks useful also
www.scu.edu/engineering/cse/ugrad/upload/COEN-2007-PROJECT-07.pdf
herselmann
PostPosted: Wed Feb 04, 2009 12:29 am     Reply with quote
Indeed, very interesting, just need more time to read...
Here is the other half of the AVR code, no more functions - just usefull defines: http://www.koders.com/c/fid5F08D29A19BB041FCD6E144C5374144AAAACF927.aspx
This is a debug output of some sort, could also be of some help: http://www.mail-archive.com/owfs-developers@lists.sourceforge.net/msg01542.html
I had a second look at the datasheet, and it contains the complete search function, can't see why this code would not want to work. Have you tried tech support? Post or PM me some code and I will see if I can have a look at it.
MikeW
Succes thanks to Kenny
PostPosted: Wed Feb 04, 2009 6:12 am     Reply with quote
I sent a pm to Kenny, after searching the forum on DS2482.
He sent me complete code.
I just started a new project, loaded his code, and away it went, detected my DS18B20.
Wonderful !!!
Many thanks Kenny.
I wont post his code without his consent.
Mike
