haseeb1431
What is CCS and pwm in mcu |
Posted: Wed Apr 29, 2009 6:58 am |
i cannot understand that basically what is ccs and pwm and how these
work _________________ i love to work |
bungee-
Re: What is CCS and pwm in mcu |
Posted: Wed Apr 29, 2009 7:46 am |
haseeb1431 wrote: | i cannot understand that basically what is ccs and pwm and how these
work |
CCS <--- C compiler from CCS company
pwm <--- Pulse Width Modulation
Use google for pwm .... ccs ---> www.ccsinfo.com |
haseeb1431
Posted: Wed Apr 29, 2009 7:56 am |
ccs not this way
we used this functions in picc compiler as
set_ccp(ccp_pwm)??? _________________ i love to work |
Posted: Wed Apr 29, 2009 10:06 am |
CCP, not CCS......
CCP. Stands for 'Capture Compare PWM'. Basically a hardware counter in the chip, that can be configured to capture times when an external signal occurs (capture). Compare a constant value, with a timer, and trigger when they match (Compare), or generate a PWM output, based upon an internal clock, and a width value (PWM). The setting you post, configures the module, to perform the latter function.
Microchip, have a number of application notes about their CCP modules. Read them.....
