Instruction cycle time
Snowblind
PostPosted: Mon Nov 26, 2001 1:20 pm     Reply with quote
<font face="Courier New" size=-1>At 4mhz on a 16c84 the Instruction time is what?
I think its 4us, but im not sure.
Can you show me how you came up with the number?
Using the 2465.c driver how long would it take to read a byte from that device?</font>
___________________________
Original Post ID: 1325
Eugene
Re: Instruction cycle time
PostPosted: Mon Nov 26, 2001 2:30 pm     Reply with quote
I don't know if the 16c84 is the same as the 16c74 but if it is then here is the calcualation
1/[4 000 000(xtl speed)/4(osc per instructions)]
so you get 1ns
:=<font face="Courier New" size=-1>At 4mhz on a 16c84 the Instruction time is what?
:=I think its 4us, but im not sure.
:=Can you show me how you came up with the number?
:=Using the 2465.c driver how long would it take to read a byte from that device?</font>
Original Post ID: 1328
PostPosted: Mon Nov 26, 2001 2:59 pm     Reply with quote
:=At 4mhz on a 16c84 the Instruction time is what?
Microchip does not list the 16c84 on their web site anymore.
But you can find the data sheet archived on a few web sites if
you search the net.
But, if you look in the 16F84a data sheet, in the section
called "Instruction Set Summary", it has a paragraph that
explains it all.
To measure the time to read a byte using the 2465.c driver,
I would use a logic analyzer to capture the waveform. Or, you
could use an oscilloscope.
The 16c84 or F84 can't do hardware i2c. You have to use
the CCS software i2c library. But at slow clock speeds like
4 MHz, the CCS code can't run at 100 KHz. It runs at approximately 40 KHz. That's 25 usec per bit. You could
look at the data sheet for the 2465, and see how many i2c
bit-times that it takes to do a read operation. Then compare
their diagram to the CCS code in 2465.c to make sure that
CCS does it the same way. Then multiply the number of bit-times
by 24 usec to get the total.
But Microchip doesn't admit that they even make the 2465,
(or once made it) if you look on their web page.
Original Post ID: 1329
Sherpa Doug
PostPosted: Mon Nov 26, 2001 4:16 pm     Reply with quote
:=I don't know if the 16c84 is the same as the 16c74 but if it is then here is the calcualation
:=1/[4 000 000(xtl speed)/4(osc per instructions)]
:=so you get 1ns
Make that 1 microsecond!
:=:=Using the 2465.c driver how long would it take to read a byte from that device?
You COULD count all the instructions needed to do a read, but the other suggestions from PCM programmer are much better.
Original Post ID: 1330
Snowblind
PostPosted: Mon Nov 26, 2001 6:36 pm     Reply with quote
:=You COULD count all the instructions needed to do a read, but :=the other suggestions from PCM programmer are much better.
Well I wish I had a oscilloscope, any of you have one you reccommend for someone doing this as a hobby
btw, thanks for all the replys everyone
Original Post ID: 1332
Sherpa Doug
PostPosted: Wed Nov 28, 2001 7:56 am     Reply with quote
You could write a test program that does 1000 reads and toggles an LED. Then use a stopwatch to get the timing.
It is hard without the proper tools.
Sherpa Doug
:=:=You COULD count all the instructions needed to do a read, but :=the other suggestions from PCM programmer are much better.
:=Well I wish I had a oscilloscope, any of you have one you reccommend for someone doing this as a hobby
:=btw, thanks for all the replys everyone
Original Post ID: 1350
