SPI register settings
halliburtonboy
PostPosted: Thu Jan 29, 2009 10:56 am     Reply with quote
All,
I have never used SPI and need to learn more about using it for an lcd project. I am using the classic NOKIA 6100 code from sparkfun electronics which includes the use of SPI clock and data ouput.
I have modified the free code from the sparkfun website for use with my 18F4580 chipset with one exception. I have not changed this line of code
#bit SSPEN = 0x14.5
for use with my chip....it may even be the same setting for both chipsets but I would liike to understand how to turn on the MMSP SPI module myself rather than just borrow code.
thanks for any help...
I am using pcw and have been using pics for over 4 years now, so I understand most other registers like ADCON, CCP, etc, I have just never messed with SPI.
Here is my complete LCD program (borrowed and modified).
//// Marcus Russell
//// Russell Evolutions Inc.
//// Nokia 6100 LCD with Epson S1D15G10 Controller
////  sample initialization program for PIC16LF872 in CCS C  3-14-07
//// Based on Spark Fun Electronics Code by Owen Osborn 1-22-05
////   with thanks to David Carne of SFE for DISCTL help
////   and user 'Ttelmah' from CCS C forum for SSPEN bit idea for 9-bit hardware SPI
//// You are free to use this code for any purpose.
//// START OF HEADER FILE ////
//#include <16F872.h>
#include <18F4580.h>
#device adc=8
//#FUSES XT                       //Crystal Osc (<= 4mhz)
#FUSES HS                       //HIGH SPEED OSC
#FUSES PUT                      //Power Up Timer
#FUSES NOBROWNOUT               //Don't Reset when brownout detected
#define LCD_RESET   PIN_C0
#define LCD_CS   PIN_C1
#define SPI_CLK   PIN_C3
#define SPI_DI   PIN_C4 //unused
#define SPI_DO   PIN_C5
#bit SSPEN = 0x14.5   // bit to turn on/off hardware SPI
// Epson S1D15G10 Command Set
#define DISON       0xaf
#define DISOFF      0xae
#define DISNOR      0xa6
#define DISINV      0xa7
#define SLPIN       0x95
#define SLPOUT      0x94
#define COMSCN      0xbb
#define DISCTL      0xca
#define PASET       0x75
#define CASET       0x15
#define DATCTL      0xbc
#define RGBSET8     0xce
#define RAMWR       0x5c
#define RAMRD       0x5d
#define PTLIN       0xa8
#define PTLOUT      0xa9
#define RMWIN       0xe0
#define RMWOUT      0xee
#define ASCSET      0xaa
#define SCSTART     0xab
#define OSCON       0xd1
#define OSCOFF      0xd2
#define PWRCTR      0x20
#define VOLCTR      0x81
#define VOLUP       0xd6
#define VOLDOWN     0xd7
#define TMPGRD      0x82
#define EPCTIN      0xcd
#define EPCOUT      0xcc
#define EPMWR       0xfc
#define EPMRD       0xfd
#define EPSRRD1     0x7c
#define EPSRRD2     0x7d
#define NOP         0x25
#define ENDPAGE     132
#define ENDCOL      130
////  START OF MAIN .C SOURCE FILE ////
//#include "<path to .h file cut from above>"
#use fast_io(C)
void pset(unsigned char color, unsigned char x, unsigned char y);
void spi_command(int);
void spi_data(int);
   int16 i;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED, 0, 1);
   set_tris_c(0x00);   // all outputs, can change to mask only hardware SPI bits if needed
   // reset display
   output_low (SPI_CLK);
   output_low (SPI_DO);
   output_high (LCD_CS);
   output_low (LCD_RESET);
   output_high (LCD_RESET);
   //init'd, now drop CS to send commands/data and raise when finished
    spi_command(DISCTL);  // display control
    spi_data(0x0C);      // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
    spi_data(0x20);      // 32 = (128/4)-1 (round up) number of display lines for scanning
    spi_data(0x0C);      // 12 = 1100 - number of lines to be inversely highlighted
    spi_data(0x00);
    spi_command(COMSCN);  // common scanning direction
    spi_data(0x01);
    // 0 0 0 =   1 -> 80   81 -> 160
    // 0 0 1 =   1 -> 80   81 <- 160
    // 0 1 0 =   1 <- 80   81 -> 160
    // 0 1 1 =   1 <- 80   81 <- 160
    spi_command(OSCON);  // internal oscialltor ON
    spi_command(SLPOUT);  // sleep out
    spi_command(VOLCTR);  // electronic volume, this is the contrast/brightness
    spi_data(0x23);   // volume (contrast) setting - fine tuning
    spi_data(0x03);   // internal resistor ratio - coarse adjustment
    spi_command(PWRCTR);  // power ctrl
    spi_data(0x0f);      //everything on, no external reference resistors
    spi_command(DISINV);  // invert display mode
    spi_command(DATCTL);  // data control
    spi_data(0x00);   // normal display of page/column address, page scan direction
    spi_data(0x00);   // normal RGB arrangement
    spi_data(0x01);   // 8-bit grayscale
    spi_command(RGBSET8);   // setup 8-bit color lookup table  [RRRGGGBB]
    //RED
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    // GREEN
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    //BLUE
    spi_data(0);
    spi_data(4);
    spi_data(9);
    spi_data(15);
    spi_command(NOP);  // nop
  pset(0b11100000, 0, 0); // red pixel top left (also sets start of bulk write, see pset routine)
  for (i = 1; i <= 16900; i++) {  // 130x130 = 16900
      spi_data(0b11100000);   // fill screen red
  spi_command(DISON);   // display on
  while (1) {  // main program loop.  just blinks A0 to show chip is running
      output_toggle(PIN_E0);
void pset(unsigned char color, unsigned char x, unsigned char y){
//  sets the starting page(row) and column (x & y) coordinates in ram,
//  then writes the colour to display memory.  The ending x & y are left
//  maxed out so one can continue sending colour data bytes to the 'open'
//  RAMWR command to fill further memory.  issuing any other command
//  finishes RAMWR.
  x += 2;                  // for some reason starts at 2
  spi_command(PASET);   // page start/end ram
  spi_data(x);
  spi_data(ENDPAGE);
  spi_command(CASET);   // column start/end ram
  spi_data(y);
  spi_data(ENDCOL);
  spi_command(RAMWR);    // write
  spi_data(color);
void spi_command(int dat){
   output_low(LCD_CS);      // enable chip
   SSPEN = 0;               // shut off hardware SPI allowing direct access to SPI in/out pins
   output_low (SPI_DO);     // output low on data out (9th bit low = command)
   output_high (SPI_CLK);
   delay_cycles(1);         // send clock pulse
   SSPEN=1;                 // turn hardware SPI back on
   spi_write(dat);          // make PIC do the work for the command byte
   output_high(LCD_CS);     // disable
void spi_data(int dat){
   SSPEN = 0;               // turn off hardware SPI allowing us direct access to SPI in/out pins
   output_high (SPI_DO);    // output high on data out (9th bit high = data)
   spi_write(dat);          // make PIC do the work for the data byte
could someone p
PostPosted: Thu Jan 29, 2009 1:12 pm     Reply with quote
#bit SSPEN = 0x14.5
You asked the same question a week ago in this thread
and I gave you an answer at that time.
http://www.ccsinfo.com/forum/viewtopic.php?t=37345&start=10
