problem with code output
metacase
PostPosted: Tue Jan 27, 2009 2:10 pm     Reply with quote
hi!
i'm making a 4 microphone array to recognize a source of sound, like voice.
The algorithm which returns the angle of the ubication of the source need the next function.
unsigned long dot_product(unsigned int mic1,unsigned int mic2, int desfase)
      unsigned long p;
      int i,j;
      p = 0;
      for(i=0;i<BUFFER_SIZE;i++){
      j = (i + desfase + BUFFER_SIZE)%BUFFER_SIZE;
      p = p + (unsigned long)(((buffer[4*i + mic1]>>2)*(buffer[4*j + mic2]>>2))>>5);
      return p;
note: BUFFER_SIZE=64
the problem is that i don't understand the meaning of the last line.
thanks!
PostPosted: Tue Jan 27, 2009 8:41 pm     Reply with quote
Do you mean the last line in the calculations ?
Did you get this code from some webpage ? If so, post a link to the
webpage.
PostPosted: Wed Jan 28, 2009 7:41 am     Reply with quote
webpage.
yeah, the last line, i got the code from a student who did this project long time ago, at that time the project worked, but now is not working, so i have to fix it.
PostPosted: Wed Jan 28, 2009 9:32 am     Reply with quote
How is buffer declared?.
Was the code written in CCS C originally, or in another C?.
PostPosted: Wed Jan 28, 2009 10:51 am     Reply with quote
I have the answer:
it's a cross correlation between one signal from mic_1 and the other signal from mic_2.
thanks.
