unwanted 'break' during debug
PostPosted: Wed Mar 04, 2009 5:34 pm     Reply with quote
I am playing with an ICD and when I started designing my INT_EXT interrupt it now breaks when the interrupt routine is supposed to fire off.
In other words, when I have a falling edge on B0 the software halts in the middle of my:
 for(;;){
//lots o' code
This is without any breakpoints enabled in the code. And what's really annoying, my interrupt routine isn't being run. I'm using PCH version 4.082
I'm going through and putting #if 0 around large sections of code just to see if that does anything.
If anyone has seen something like this I would love to know.
PostPosted: Wed Mar 04, 2009 5:56 pm     Reply with quote
Post your PIC. Post your ICD manufacturer and full ICD name.
PostPosted: Thu Mar 05, 2009 7:30 am     Reply with quote
PIC 18F4680
ICD is a Microchip MPLAB ICD2
PostPosted: Thu Mar 05, 2009 8:39 am     Reply with quote
I've ripped all my code out and it still happens.
When I get an external interrupt on the B0 pin it breaks at the while(1) even if I don't have any breakpoints enabled.
#define 18F4680
#include <18F4680.h>
#DEVICE HIGH_INTS=TRUE
#OPT 0
void init_hardware(void);
#include "device.h"
unsigned char test3=0;
unsigned char test2=0;
unsigned char SendIdentDevFlag = FALSE;
   delay_ms(500);               //Let the CP power up
   init_hardware();
   while(1){}
   *TRISA = 0x20;
   *TRISB = 0xE7;
   *TRISC = 0x91;
   *TRISD = 0x00;
   *TRISE = 0x08;
   bit_clear(*INTCON2,RBPU);               //Enable the pullup resister for PORTB
   /*   Set up async usart                           */
   /*  19200 WAS 576000 8-N-1                        */
   /*  High Baud Rate (BRGH = 1) 16 if 1, 64 if 0         */
   /*   SPBRG = ((Fosc/Desired Baud Rate)/16) - 1         */
   /*   SPBRG = ((3686400/57600)/16) - 1               */
   /*   SPBRG = 3                                 */
   *SPBRG = 47;
   bit_set(*TXSTA,BRGH);               //High speed
   bit_set(*BAUDCON,BRG16);            //16-bit
   bit_clear(*TXSTA,SYNC);               //Asyncronous
   bit_set(*RCSTA,SPEN);               //Enable Serial Port
   bit_set(*RCSTA,CREN);               //Enable receiver
   /*   SPI Setup                                  */
   setup_spi(SPI_MASTER | SPI_CLK_DIV_64 | SPI_L_TO_H);
   bit_set(*SSPCON1, SSPEN);            //Enable Sync Serial Port
   bit_clear(*SSPSTAT, SMP);            //Input data sampled at end of data output
   bit_clear(*SSPCON1, CKP);            //Clock zero at idle
   bit_clear(*SSPSTAT, CKE);            //Transmit on clock transition from Idle to Active (Low to High)
   /*   The max speed of this device is 75kHz.            */
   /*   Fosc/divisor = SPI clock speed                  */
   /*   3686400/64 = 57.6kHz is the actual clock speed      */
   /*   Setup Timer                                 */
   /*   Internal speed = Fosc/4 = 921600               */
   /*                  Interval of 1ms      Error      */
   /*   No prescale:   1.1 usec       922      0.07%      */
   /*   Prescale 2:      2.2 usec      461      0.17%      */
   /*   Prescale 4:      4.3 usec      230      0.17%      */
   /*   Prescale 8:      8.7 usec      115      0.17%      */
   /*   Prescale 16:   17.4 usec      58      1.01%      */
   /*   Prescale 32:   34.7 usec      29      2.86%      */
   /*   Prescale 64:   69.4 usec      14      2.86%      */
   setup_timer_1(T1_INTERNAL| T1_DIV_BY_1);//| RTCC_8_BIT);
   /*   Setup CCP (Capture/Compare)                     */
   /*   Interrupt on compare                        */
   //setup_ccp1(CCP_COMPARE_RESET_TIMER);
   //CCP_1 = 922;
   /*   Set Up Interrupts                           */
   //ext_int_edge(INT_RDA,H_TO_L);
   ext_int_edge(0,H_TO_L);
   ext_int_edge(1,H_TO_L);
   setup_wdt(WDT_OFF);
   enable_interrupts(INT_RDA);
    clear_interrupt(INT_EXT);
   enable_interrupts(INT_EXT);
   //enable_interrupts(INT_EXT1);
   disable_interrupts(INT_EXT1);
   disable_interrupts(INT_RB);
   //enable_interrupts(INT_CCP1);
   //enable_interrupts(INT_TIMER1);  DO NOT USE
   //disable_interrupts(GLOBAL);
PostPosted: Thu Mar 05, 2009 10:21 am     Reply with quote
Er. Of course it will.
You are enabling the interrupts, but have not declared an interrupt handler. There is no code present for the interrupt to go to....
PostPosted: Thu Mar 05, 2009 10:27 am     Reply with quote
Cut and Paste Error:
#int_EXT
void ext_isr()
   unsigned char testme = 0;
   SendIdentDevFlag = TRUE;
   testme = 5;
   if(testme == 5)
      testme++;
   init_hardware();
   while(1){}
   *TRISA = 0x20;
   *TRISB = 0xE7;
   *TRISC = 0x91;
   *TRISD = 0x00;
   *TRISE = 0x08;
   /*   SPBRG = 3                                 */
   *SPBRG = 47;
   /*   SPI Setup                                  */
   /*   Setup Timer                                 */
   //CCP_1 = 922;
   setup_wdt(WDT_OFF);
   //enable_interrupts(INT_RDA);
   disable_interrupts(INT_EXT2);
   //enable_interrupts(GLOBAL);
PostPosted: Thu Mar 05, 2009 10:32 am     Reply with quote
Get rid of the line HIGH_INTS=TRUE.
You are enabling high priority interrupts, but have not declared any interrupt high priority, so no handler will be present for these. _However_, INT_EXT, is automatically made high priority if these are enabled. So INT_EXT, will vector to the non existent handler, and will never reach it's intended handler.
HIGH_INTS=TRUE, should only ever be set, if you are using high priority interrupts.
PostPosted: Thu Mar 05, 2009 10:38 am     Reply with quote
Done, and still happening.
PostPosted: Thu Mar 05, 2009 10:57 am     Reply with quote
There are several things in your code that 'worry' me.
First, your accesses using TRISA etc., as pointers. You have not 'typed' these, so it is very likely that the results will not be as expected. Why not use the CCS TRIS functions?.
Then the same applies for setting the register pullups.
Then the same for setting the serial port.
Then the same for the SPI. You half let the compiler do it, then go manual.
If you want to write your code like assembler, then use assembler. If you are going to use a compiler, why not let it do it's work?.
You don't show your fuses, you don't show your clock definition, etc. etc..
At this point, knowing how the registers have really been setup, is hard.
Seriously, you could do a basic program, in less than 30 lines, that does everything you are showing. This should be compilable, so we can see the problem. If this still behaves the same way, then it is almost certainly a ICD problem, but with what you post, it could easily be something unexpected happening...
