switch/ if-else
praveen hegde
switch/ if-else
PostPosted: Tue Jan 20, 2009 9:19 pm     Reply with quote
Which of the following consume more memory(ROM space):
1. switch
2. if-else
and which is faster in CCS compiler?
PostPosted: Tue Jan 20, 2009 9:35 pm     Reply with quote
Make a test program that uses those statements and look at the .LST file.
You can find the answer by this method.
PostPosted: Wed Jan 21, 2009 4:02 am     Reply with quote
Also, try with and without a 'default' statement on the switch. Makes an important difference...
