setup_spi error; maybe a bug?
PostPosted: Sat Jan 24, 2009 7:31 am     Reply with quote
Hi
Is the setup_spi doing the right thing?
(PIC 18xx2455 PCW 4.083)
If using PortB.1 as input it wont work because the tris is set to output?
Maybe a compiler bug?
The setup_spi can work without the tris setting.
setup_spi(SPI_SS_DISABLED);
0B22:  BCF    SSPCON1.SSPEN
0B24:  BCF    TRISC.7
0B26:  BSF    TRISB.0
0B28:  BCF    TRISB.1
0B2A:  MOVLW  01
0B2C:  MOVWF  SSPCON1
0B2E:  MOVLW  00
0B30:  MOVWF  SSPSTAT
PostPosted: Sat Jan 24, 2009 1:04 pm     Reply with quote
You're keeping the SPI module active, but only disabling Slave Select.
To completely disable it and have it not touch the TRIS, do it like this.
.................... setup_spi(FALSE);
0018:  CLRF   SSPCON1
