Can use External interrupt and Port change interrupt
maaply
PostPosted: Thu Jan 15, 2009 4:17 am     Reply with quote
Hi all,
I am trying to use both interrupt in PORT B. Below is my code, problem is this, always PORT B change interrupt only servicing even the INT pin get the signal. The External interrupt never servicing... How can I make it work ?
#include "D:\mahesh\Shakira_Development_Modules\CCS\15-01-2009\main.h"
#define RESET   PIN_C2
#int_RB
void  RB_isr(void)
output_high(RESET);
delay_cycles(10);
output_low(RESET);
#int_EXT
void  EXT_isr(void)
output_high(RESET);
delay_cycles(10);
output_low(RESET);
#int_TIMER1
void  TIMER1_isr(void)
output_high(RESET);
delay_cycles(10);
output_low(RESET);
   setup_oscillator(OSC_16MHZ);
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
   setup_vref(FALSE);
  // enable_interrupts(INT_RB3);
   disable_interrupts(INT_RB0);
   enable_interrupts(INT_EXT);
   ext_int_edge( H_TO_L );      // Sets up EXT
set_tris_c(0x00);
set_tris_b(0x09);
//IOCB=0x08;
Thanks,
maaply
PostPosted: Thu Jan 15, 2009 5:11 am     Reply with quote
You will.
Key thing, is that with the 'port changed' interrupt, once triggered, it will keep on triggering 'for ever', till you reset the port latch. This is separate from the interrupt flag (which the compiler will try to reset for you). It is reset, _by the act of reading the port_. Hence when using INT_RB, you _must_ read PortB in the interrupt handler. If you don't, this interrupt will keep triggering.
The same is true of the serial receive interrupt (where you must read the received byte), and the serial transmit interrupt (where you must write a byte to the output latch).
Since you never read the port, the interrupt once fired, will continue for ever...
What chip is this?. On most chips, the INT_RB interrupt is on the high four PortB pins. On the ones where it is available on the low pins, RB0, can be used for _either_ a change interrupt, _or_ a level interrupt, not both. So, 'which chip'.
maaply
PostPosted: Thu Jan 15, 2009 7:13 pm     Reply with quote
Thanks Ttelmeh,
This for 16F722 controller. The external interrupt is in PB0 and port change interrupt is in PB3. Even i read the PORT B, RBIF is not reset in simulator.
Thanks,
maaply
PostPosted: Thu Jan 15, 2009 8:35 pm     Reply with quote
Post your current #int_rb routine.
maaply
PostPosted: Fri Jan 16, 2009 12:19 am     Reply with quote
#include <16LF723.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES MCLR                     //Master Clear pin enabled
//#FUSES BORV19                #FUSES PLLEN                 #FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOVCAP
#use delay(clock=8000000)
#define I2C_SCL   PIN_B4
#define I2C_SDA   PIN_B5
#define SPI_CLK   PIN_C3
#define SPI_DI   PIN_C4
#define SPI_DO   PIN_C5
#use rs232(baud=10417,parity=E,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use i2c(Master,Fast,sda=PIN_B5,scl=PIN_B4)
#int_EXT
void  EXT_isr(void)
output_low(RESET);
#int_RB
void  RB_isr(void)
char a;
a=input_b();
output_high(RESET);
#int_TIMER1
output_high(RESET);
delay_cycles(10);
output_low(RESET);
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
set_tris_c(0x00);
   // TODO: USER CODE!!
can i use separately
PostPosted: Mon Jan 19, 2009 9:29 pm     Reply with quote
Thanks PP,
Can you please help me to come out from this problem?
Is it possible to use this 2 interrupt ( Port Change and External) separately?
Because, even i give the pulse to int pin the #int_RB isr routine is executing.
The IOCB register is loaded value 0x08.
maaply
