Optimisation levels
EdWaugh
Optimisation levels
PostPosted: Tue Jan 20, 2009 4:30 am     Reply with quote
Hi all,
I've managed to get myself the latest version of the compiler and was having a play with the optimisation settings. I normally use 9 so I was trying 10 and 11.
At level 10 the following code gets broken and calculates incorrect results:
uint16_t generate_16bit_crc(uint8_t* data, uint16_t length, uint16_t pattern)
   uint8_t* current_data;
   uint16_t crc_Dbyte;
   uint16_t byte_counter;
   uint8_t bit_counter;
   current_data = (uint8_t*)(data + 2);
   crc_Dbyte =  make16(data[0], data[1]);
   for(byte_counter=0; byte_counter < (length-2); byte_counter++)
      for(bit_counter=0; bit_counter < 8; bit_counter++)
         if(!bit_test(crc_Dbyte,15))
            crc_Dbyte <<= 1;
            bit_test(*current_data, 7 - bit_counter) ?
               bit_set(crc_Dbyte,0) : bit_clear(crc_Dbyte,0);
            continue;
         crc_Dbyte <<= 1;
         crc_Dbyte ^= pattern;
      current_data++;
   for(bit_counter=0; bit_counter < 16; bit_counter++)
         crc_Dbyte <<= 1;
         continue;
      crc_Dbyte <<= 1;
   return crc_Dbyte;
This is actually just the CCS CRC generator from v3. Setting opt to 9 makes this work correctly, at level 10 it calculates incorrect CRCs and at 11 I get the compiler error:
Internal Error - Contact CCS LABEL SCR=18907
I have also emailed CCS, any thoughts about this and what is the best opt level to stick to would be appreciated.
thanks
ed[/code]
PostPosted: Tue Jan 20, 2009 2:38 pm     Reply with quote
I never change the default #opt level. I just consider the other levels
to be experimental. If you want to find the problem, print out the .LST
files for both #opt levels and compare the ASM code.
