Help for compiler error!
rougie
PostPosted: Tue Jan 20, 2009 1:03 pm     Reply with quote
Hello, please consider the following code:
=================================== krn.h
typedef long *LRESULT;
typedef long WPARAM;
typedef long LPARAM;
typedef struct tagHwnd{
void *handle;
} HWND;
typedef LRESULT (*WNDPROC)(HWND, long, WPARAM, LPARAM);
typedef struct tagWnd{
WNDPROC  lpfnWndProc;
int      style;
long     backGround;
long     titleMsg;
long     extra;
} WND, *pWND;
typedef struct tagRwp{
HWND     hwnd;
int      showWinEnable;
} RWP;
typedef struct tagMsg{
HWND    hwnd;
long    msg;
WPARAM  wParam;
LPARAM  lParam;
long    time;
} KM_MSG, *pKM_MSG;
RWP rwp[3] = {0,0,0,0,0,0};
void ULC_KERNEL_dispatch_message(KM_MSG *K);
================================krn.c
#include <Dv4685.h>              // DEVICE INNITIALIZATIONS
#include <stdlib.h>              // CCS LIBRARY STANDARD LIBRARY
#include <KERNEL.h>              // KERNEL HEADER FILE!
LRESULT KWP(HWND x, long m, WPARAM w, LPARAM l);
LRESULT callerFunction(LRESULT (*WNDPROC) (HWND, long, WPARAM,
LPARAM), HWND h, long m, WPARAM w, LPARAM l);
KM_MSG  u;           // Create an KM_MSG object
pKM_MSG msg = &u;    // Assign the address of a KM_MSG object to a pKM_MSG pointer object
WND     wnd;         // Create a WND object
// DEFINE A WINDOW!
wnd.lpfnWndProc   = KWP;   // Assign a function pointer ! (Assigns the pointer to a function called KWP  !!! )
wnd.style         = 0;     // Assign other stuff...
wnd.backGround    = 0;     // Assign other stuff...
wnd.titleMsg      = 0;     // Assign other stuff...
wnd.extra         = 0;     // Assign other stuff...
// Assign the address of a wnd object to the void pointer called "handle"
//which is a member of tagHwnd structure
(rwp[0].hwnd).handle = &wnd;
msg->hwnd = rwp[0].hwnd;       // Assign a hwnd to another hwnd
ULC_KERNEL_dispatch_message(msg);  // Pass a pointer to a msg object
void ULC_KERNEL_dispatch_message(KM_MSG *msg)
LRESULT zzz;
// Call the correct function based on the contents of the function pointer
// stored in "lpfnWndProc"
zzz = callerFunction(( (struct tagWnd*) (msg->hwnd).handle)->lpfnWndProc, msg->hwnd, msg->msg, msg->wParam, msg->lParam);
//CALLBACK FUNCTION IMPLEMENTATION
LRESULT callerFunction(LRESULT(*WNDPROC)(HWND, long, WPARAM, LPARAM) ,HWND h, long m, WPARAM w, LPARAM l)
   WNDPROC (h, m, w, l);
   return 0;
//... other code ...
return 0;
Errors do occur at compile time!
In reference to the sample code above, here is what I am trying to do:
It is important to notice that I have defined a tagHwnd structure, like this:
void *handle;
} HWND;
And It is also important to knowthat I have also defined an array of tagRWP structures where each element of the array contains an HWND and an showWinEnable member, like this:
HWND     hwnd;
int      showWinEnable;
} RWP;
Basically what I am trying to do is, in main(), assign any function name to the lpfnWndProc member of a WND, like this:
WND     wnd;
//The following line could assign any function name.
wnd.lpfnWndProc   = KWP;   // <<< Right now we are using KWP
So if we want to reference the value in the “handle” member via the rwp[] array, we need to do this:
So getting back to what I was saying, Once I assigned function KWP to lpfnWndProc I then store the address of the WND object to the void pointer “handle”, like this.
Then I assign the hwnd member of the first element of tagRwp structures to a hwnd member in the tagMsg, like this:
The msg object now has accessibility to the "lpfnWndProc" member stored in the hwnd object. The “lpfnWndProc” member still contains the address of the function which is KWP’s address.
Next I pass the address of the msg object to the following function.
And therefore we allow the ULC_KERNEL_dispatch_message() function’s implementation to fetch the correct function based on the contents of the function pointer stored in "lpfnWndProc" by executing the following lines:
LRESULT zzz;
zzz = callerFunction(((struct tagWnd*) (msg->hwnd).handle)->lpfnWndProc, msg->hwnd, msg->msg, msg->wParam, msg->lParam);
Anybody experienced enough in using Callback types of functions this way in PICs using CCS ?
Thanking all in advance !
Regards
Roberto
