leejok2003
Jorge Amodio's ENC28J60 TCP/IP project in CCS? |
Posted: Fri Jan 02, 2009 8:59 am |
I am currently working with TCPIP stack project. I search in the internet and found this site:
http://www.ljcv.net/projects/minipic10t/index.html
I was working with the CCS development board in simulation and now I have this board from my senior. I wish to test my CCS stack program with this board but really don't have idea to modify where? Can somebody with experience help me with this feature? Which pin to change? Which program to modify?
Thanks... |
asmallri
Re: Jorge Amodio's ENC28J60 TCP/IP project in CCS? |
Posted: Sat Jan 03, 2009 10:45 am |
leejok2003 wrote: | Hi,
Thanks... |
Considerable effort is required to port Jorge's implementation of the stack to CCS. If this is for a final year project then I suggest you do not want to spend all the time required to do the port. If you cannot use the CCS TCP stack then I suggest a new post asking if anyone has ported Jorge's stack to CCS. If not then I suggest either using the CCS TCP/IP stack implementation or using the Microchip C18 compiler. _________________ Regards, Andrew
leejok2003
Posted: Thu Jan 15, 2009 1:01 pm |
I have finally got my own module on the breadboard. The ENC28j60 is working fine and connected to the PC. But somehow, when i wana ping it, it doesn't reply at all? i am using the CCS TCPIP stack, example 10b, and the circuit is based on the CCS develepment board with out the LCD and eeprom. The connection between ENC and PIC is correct...
Any ideas? |
