Need some design advice on 16F73 at 3.3v |
Posted: Thu Jan 15, 2009 11:01 am |
Hi All,
I just completed a new design using the 16F73 and an Xbee Pro module. The design is all 3.3V due to the Xbee requirements, and this is the first time I've used 3.3V in a design. I've got several prototype boards now, and just learned that the F73 is not supported at 3.3V using the ICD-U40 programmer. I'm trying to figure out the best way out of this problem to get some utility from the prototypes that are already made. Ultimately, I guess I need a new PIC that is supported at 3.3V with the ICD. suggestions??
Tim |
jgschmidt
Joined: 03 Dec 2008 Posts: 184 Location: Gresham, OR USA
Running PIC at 3.3v |
Posted: Thu Jan 15, 2009 12:54 pm |
Check your datasheet. The 16F73 runs at between 2.5 and 6 volt, as do most PICs. |
jgschmidt
Posted: Thu Jan 15, 2009 1:34 pm |
Ahh. I use the MachX, didn't realize there was a diference. |
Posted: Thu Jan 15, 2009 1:36 pm |
It looks like the 16F876A is pin-compatible and is suported at 3.3V by the ICD. Could this be a possible solution for you?
Darren |
