Stack Overflow?
rhaguiuda
Stack Overflow?
PostPosted: Wed Jan 14, 2009 6:54 am     Reply with quote
My .sta file have this line:
Stack used: 11 worst case (out of 8 total available)
I'm using a PIC16F876 in my project.
Assuming that my PIC have 8 level stack, it means that I'll have stack overflow?
If so, how can I prevent such a thing? What is the "worst case" for the compiler?
Give a man a fish and you'll feed him for a day. Teach a man to fish, and you'll feed him for a lifetime.
RLScott
Re: Stack Overflow?
PostPosted: Wed Jan 14, 2009 7:25 am     Reply with quote
Yes, it means that you will have a stack overflow if your code visits every branch on the call tree. There are two things that use up stack: function calls and interrupts. Look at the file whose extention is ".TRE" in your workspace to see the call tree. You can open it in Notepad or any text editor, or even in the IDE. Then reorganize your program to reduce the number of nested function calls. Exactly how you do this will depend too much on your particular application to give any concrete advice. But at least the call tree wil show you where the problem is.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
rhaguiuda
PostPosted: Wed Jan 14, 2009 7:31 am     Reply with quote
Thanks Robert!
