C question
mho
C question
PostPosted: Wed Jan 14, 2009 7:01 am     Reply with quote
hi!
i have the next code for I2C:
int16 read_it(){
int lsb,msb;
i2c_start();
i2c_write(0xC0);
i2c_write(0x41);
i2c_stop();
delay_ms(7);
i2c_start();
i2c_write(0xC1);
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
delay_ms(5);
[b]return((int16)msb|((int16)lsb << 8));[/b]
but i don't understand the last line, what it return?
thanks
Wayne_
PostPosted: Wed Jan 14, 2009 7:13 am     Reply with quote
msb and lsb are both 8 bit values.
the (int16) converts the var to a 16 bit var.
the << 8 shifts the lsb left by 8 bits.
the | symbol ORs the 2 values together.
So in total this converts the 2 8 bit values into a 16 bit value using the lsb as the upper 8 bits and the msb as the lower 8 bits and returns this new 16 bit value.
You have to type cast the 8 bit values to 16 bit values to be able to do this other wise the result will be an 8 bit value and would be wrong.
RLScott
Re: C question
PostPosted: Wed Jan 14, 2009 7:17 am     Reply with quote
...i don't understand the last line, what it return?
It returns the a 16-bit integer whose low-order byte is msb and whose high order byte is lsb. It seems the variable names msb and lsb are assigned or used backwards, if you think that msb means Most Significant Byte and lsb means Least Significant Byte.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
PostPosted: Wed Jan 14, 2009 8:50 am     Reply with quote
As a separate 'comment' though, the CCS compiler has the 'make16' instruction, which is generally more efficient at doing this conversion. Fortunately the optimiser is quite good now, and should automatically replace the 8 bitwise shifts, with a single 'byte' movement.
Re: C question
PostPosted: Wed Jan 14, 2009 9:48 am     Reply with quote
you're right, i've realized that i wrote it bad, it should be
return((int16)lsb|((int16)msb << 8)):
in that case, could you give me an example??
thanks!
