Debugging Problem in MPLAB on CCS compiler
harshanahnd
PostPosted: Tue Jan 06, 2009 4:26 am     Reply with quote
I was trying to debug a code that I have written for a 18F4550 PIC. I configured CCS Compiler on MPLAB. And I build the project that I have written successfully on MPLAB. No problems occurred when building the project.
But when I try to program it (Debugger => Program) following output comes,
    MPLAB ICD 2 ready for next operation
    Programming Target...
    ...Validating configuration fields
    ...Erasing Part
    ...Programming Program Memory (0x0 - 0x7DBF)
    ...Loading DebugExecutive
    ...Programming DebugExecutive
    ...Programming Debug Vector
    ...Programming RSBUG
    Verifying...
    ...Program Memory
    ...Debug Executive
    ...Debug Vector
    ...Verify Succeeded
    Programming Configuration Bits
    .. Config Memory
    Verifying configuration memory...
    ...Verify Succeeded
    Connecting to debug executive
    ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information.
I am unable to find out what is the problem in here. Oscillator frequency is set correctly. Are there any other configuration bits to be set?
Please help me.
Thanks.
PostPosted: Tue Jan 06, 2009 2:31 pm     Reply with quote
Read these threads. Make sure you're doing everything in my list of
instructions:
http://www.ccsinfo.com/forum/viewtopic.php?t=23151
http://www.ccsinfo.com/forum/viewtopic.php?t=25465
Go to the Microchip forum search page:
http://forum.microchip.com/search.aspx
In the Search Terms box, type in this:
ICD0083 18F4550
On the right side, select this forum:
- - MPLAB ICD In Circuit Debuggers
Then click the Search button and you will see many articles on your
problem.
If none of that helps, then post a very small (10 lines) test program
that demonstrates the problem. Also post your compiler version.
PostPosted: Fri Jan 09, 2009 6:43 am     Reply with quote
Thanks for your help. I was able to solve the problem by setting the ICD/ICSP configuration bit to Disabled.
16F877A and ICD2 debug not working
PostPosted: Tue Jan 13, 2009 3:56 am     Reply with quote
Hi all,
I need to test my source code on the MPLAB in circuit debugger. But it gives following errors as the output. If someone could help me on this matters, it would be very helpful to me.
Thanks a lot.
...Erasing Part
...Programming Program Memory (0x0 - 0xC6F)
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
.. Config Memory
...Verify Succeeded
ICDWarn0015: Program memory has changed since last program operation? Continue with Debug operation?
Running Target
PostPosted: Tue Jan 13, 2009 1:17 pm     Reply with quote
Did you read all those links I gave you ? Did you try any of it ?
