		| Author | Message |
		| IceMetal
				| loop problem :( |
				|  Posted: Thu Jan 08, 2009 5:21 pm |   |
				| Hi guys I'm having problem with something that to you might be very simple, I'm using the pickit2 with the ccs compiler and I just wanted to know how can I jump from one loop to the other. I created this simple program but it won't let me. The compiler gives me the error because it won't jump unless the loop I want to go is on top, I hope this makes sense to you. Thank you.
  	  | Code: |  	  | #include <16F887.h>             // header file for the PIC16F887 // includes built-in functions and constants
 // for arguments/returns.
 #FUSES NOWDT
 #FUSES NOMCLR
 #FUSES NOCPD
 #FUSES NOBROWNOUT
 #FUSES XT
 void firstloop()
 while(1){
 output_d(0xf0);
 if (getc()=='2')secondloop();
 void secondloop()
 while(1){
 output_d(0x0f);
 if (getc()=='1')firstloop();
 while(true)
 printf("Welcome:,\n\r");
 printf(" \n\r");
 printf("Press 1 for first loop\r");
 printf("Press 2 for second loop\r");
		| treitmey
				|  Posted: Thu Jan 08, 2009 5:33 pm |   |
				| you just need a prototype to show what the function looks like. But then you have recursive problem.
 try something more like this
 #FUSES NOWDT
 #FUSES NOMCLR
 #FUSES NOCPD
 #FUSES NOBROWNOUT
 #FUSES XT
 //prototypes//
 void firstloop();
 void secondloop();
 //funtions
 void firstloop()
 output_d(0xf0);
 void secondloop()
 output_d(0x0f);
 //main//
 int8 getc_val;
 printf(" \n\r");
 while(true)
 getc_val=getc();
 if (getc_val=='1')firstloop();
 if (getc_val=='2')secondloop();
		| PCM programmer
				|  Posted: Thu Jan 08, 2009 5:36 pm |   |
				| You can't do recursion. That's what you're attempting to do.  You'll get this error message:
  	  | Quote: |  	  | *** Error 69 "pcm_test.c" Line 58(0,1): Recursion not permitted  [firstloop] |
		| IceMetal
				|  Posted: Thu Jan 08, 2009 5:41 pm |   |
				| THANK YOU SO MUCH!!!!!!!!!!!!!!!!!!!!! IT WORKS!!!!!!!!!!!!!!!!!!! |  |
		| IceMetal
				|  Posted: Thu Jan 08, 2009 9:07 pm |   |
				| it worked but is not what I was trying to do but thanx...this what I'm trying to do, I have a robot that I need it to work in remote and autonomous mode, so when I send a command it has to stay in the remote loop with all the features, and when I hit another command it has to stay in the autonomous mode with diferent features, thats why I'm trying to do 2 diferent loops. make sence?? |  |
		| RLScott
				|  Posted: Thu Jan 08, 2009 10:13 pm |   |
				|  	  | IceMetal wrote: |  	  | ...when I send a command it has to stay in the remote loop with all the features, and when I hit another command it has to stay in the autonomous mode with diferent features, thats why I'm trying to do 2 diferent loops. make sense?? |
 Yes, but don't use getc() because it is blocking.  Use kbhit() to check for a new command without blocking.  If you want to use a function for loop 1 and another function for loop 2, then just have those functions return whenever kbhit() is true.  Then let the main command dispatcher loop in main decide which loop to call based on a reading of getc(), which you can do without blocking after kbhit() returns true.
 Robert Scott
 Real-Time Specialties
 Embedded Systems Consulting
		| IceMetal
				|  Posted: Thu Jan 08, 2009 10:16 pm |   |
				| but how do I go to the loop that is at the bottom when I'm on the top loop? cuz when I'm trying to do that I get an error |  |
		| FvM
				|  Posted: Fri Jan 09, 2009 12:18 am |   |
				| If you advance from the present very simple example to a real application, you most likely notice, that there are more things to do than stay in mutual exclusive loops representing different machine states.
 To my opinion, it's more suitable to have a variable representing the different states, perform conditional code depending on the variable value, e. g. in a switch construct, and change the variable value to transit to another state. The technique is called finite state machine (FSM). In contrast to your loop example, you can divide the total system state into several substates, each representec by a FSM.
 If this sounds too complex for your application, keep your intial loop example, place all loops in one function block and transit by C goto statements. This works without causing recursion issues. As a basic disadvantage, you can't perform other actions at the main program level while staying in the loop.
		| IceMetal
				|  Posted: Fri Jan 09, 2009 2:09 am |   |
				| well this is what I'm trying to do I mean I will replace the printf with output commands but just to give you an idea why I want to stay in the same loop,
 #FUSES NOWDT
 #FUSES NOMCLR
 #FUSES NOCPD
 #FUSES NOBROWNOUT
 #FUSES XT
 //remote loop
 void remote()
 while(1){
 if (getc()=='4')printf("go foward\r");
 if (getc()=='5')printf("go left\r");
 if (getc()=='6')printf("go right\r");
 if (getc()=='2')autonomous();
 //autonomous loop
 void autonomous()
 while(1){
 while(Input(PIN_A1))printf("go left\r");
 while(Input(PIN_A2))printf("go right\r");
 if (getc()=='1')remote();
 //main//
 printf(" \n\r");
 printf("Press 1 for remote\r");
 printf("Press 2 for autonomous\r");
 while(true)
		| Wayne_
				|  Posted: Fri Jan 09, 2009 3:53 am |   |
				| I can't believe FvM sugested using goto to fix your problem!
 You have 2 options, The first requires very little change to the way your are doing it but will limit you to only the 2 loops. And is basically a really silly way to do it.
 The break instruction will exit a while loop!
  	  | Code: |  	  | //remote loop
 void remote()
 while(1){
 if (getc()=='2')break;
 //autonomous loop
 void autonomous()
 while(1){
 if (getc()=='1')break;
 //main//
 printf(" \n\r");
 while(true)
 if (getc()=='1') {
 while(true) {
 remote();
 autonomous();
 if (getc()=='2') {
 while(true) {
 autonomous();
 remote();
 I was just going to try and show you the second way but before I do that there are really big problems with your code. As pointed out, by using getc you code will stop and wait for a keypress before continuing, it may appear to be working ok but you should have noticed that you need to send  the same value several times for it to perform the correct action!
 Also by fixing this you will simplify your code:-
  	  | Code: |  	  |
 //remote loop
 void remote(int key)
 if (key=='4')printf("go foward\r");
 if (key=='5')printf("go left\r");
 if (key=='6')printf("go right\r");
 //autonomous loop
 void autonomous()
 //main//
 int mode = 0
 int key;
 printf(" \n\r");
 while(true)
 if (kbhit())  // If a key has been pressed
 key = getc();  // Save the key
 key = 0;
 if (key == '1')
 mode = 1;
 else if (key == '2')
 mode = 2;
 if (mode==1)remote(key);
 if (mode==2)autonomous();
 This will make it work the same way where you have to hold a key down to make it perform that action continously, but if you want it to continue the same action even if you let go of the key then just remove the
 key = 0;
 lines.
		| IceMetal
				|  Posted: Fri Jan 09, 2009 12:35 pm |   |
				| thank you so much Wayne that really helped me alot!!!!!!!!!!!!!!!!!!!! |  |
		| FvM
				|  Posted: Fri Jan 09, 2009 12:45 pm |   |
				|  	  | Quote: |  	  | I can't believe FvM sugested using goto to fix your problem! |
 Believe it or not! Basically, I mentioned why staying in a loop most likely isn't a solution for a real application. But if it would be, goto is a suitable solution, you can use a lot of others too. It's legal C code.
  	  | Code: |  	  | void main() {
 char c;
 printf(" \n\r");
 while(true)
 c=getc();
 if (c =='1')
 while(1){
 remote:
 c=getc();
 if (c =='4')printf("go foward\r");
 if (c =='5')printf("go left\r");
 if (c =='6')printf("go right\r");
 if (c =='2') goto  autonomous;
 if (c =='2')
 while(1){
 autonomous:
 if (kbhit() && getc()=='1') goto remote;
		| andrewg
				|  Posted: Fri Jan 09, 2009 9:29 pm |   |
				| Gotos really should be avoided, particularly for such a simple loop. My first take was: but I didn't like the duplicate code for left/right/forwards. So then I came up with: 	  | Code: |  	  | void main() {
 int1 remote = TRUE;
 for (;;)
 if (kbhit())
 switch (getc())
 case '1':
 remote = TRUE;
 case '2':
 remote = FALSE;
 case '4':
 if (remote) printf("go forward\r");
 case '5':
 if (remote) printf("go left\r");
 case '6':
 if (remote) printf("go right\r");
 if (!remote)
 if (input(PIN_A1)) printf("go left\r");
 if (input(PIN_A2)) printf("go right\r");
 All the previous code examples suffer from the potential problem in autonomous mode where if the inputs stay high, you'll never be able to switch to remote mode. 	  | Code: |  	  | void main() {
 int1 remote = TRUE;
 for (;;)
 int8 c = 0;
 if (kbhit())
 c = getc();
 if (!remote && c >= '4') c = 0; // no remote control in autonomous mode
 else if (!remote)
 c = '4';
 if (input(PIN_A1)) c = '5';
 if (input(PIN_A2)) c = '6';
 switch (c)
 case '1':
 remote = TRUE;
 case '2':
 remote = FALSE;
 case '4':
 case '5':
 case '6':
 Andrew
		| FvM
				|  Posted: Sat Jan 10, 2009 3:43 am |   |
				| Any arguments? 	  | Quote: |  	  | Gotos really should be avoided |
 To my opinion,you really should avoid to code state machines in an unstructurized way. For this reason, any of the suggested  examples is effectively bad coding style (at least from an embedded application point of view). My goto version simply emphasizes this bad style instead of hiding it. You immediately see, that you're stuck in a loop, as apparently intended.
 To find a better coding style, you should analyze the application purpose first and define a meaningful behaviour. The original post indicates, that this hasn't been done yet. It's generally difficult to apply improvements to an inconsistent code.
		| andrewg
				|  Posted: Sat Jan 10, 2009 7:59 pm |   |
				| Speaking of coding style, something I meant to mention before relates to the first two code samples provided by IceMetal:
 http://www.ccsinfo.com/forum/viewtopic.php?p=109099#109099
 http://www.ccsinfo.com/forum/viewtopic.php?p=109115#109115
 They are just plain wrong under all circumstances, from embedded systems to supercomputers. The problem is that firstloop() and secondloop() are always calling each other and never returning. This will eventually cause any computer to run out of memory and crash. Embedded systems will just get there first due to less memory.
 Andrew
