PIC18F87J60 oscillator problem
EdwardH
PostPosted: Tue Jan 13, 2009 9:34 am     Reply with quote
I'm trying to write a program for the PIC18F87J60 and I started with a simple LED flash, however when I run this on the chip the LED flashes with only a 5.28uS delay not 500ms. There's a 25MHz crystal attached.
Any ideas? I've tried manually setting the OSCTUNE register etc with no success.
Edward
#include <18F87J60.h>
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc
#FUSES XINST                    //Extended set extension and Indexed Addressing mode enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#FUSES ECCPE                    //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
#FUSES ETHLED                   //Ethernet LED enabled
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=25MHZ, oscillator=25MHZ)
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_4(T4_DISABLED,0,1);
   setup_vref(FALSE);
   output_high(PIN_B3);
   while (1)
      output_low(PIN_B2);
      output_high(PIN_B2);
PostPosted: Tue Jan 13, 2009 9:49 am     Reply with quote
The CCS compiler does not support XINST. May not be the problem, but code is unlikely to work right with this fuse set.
EdwardH
PostPosted: Tue Jan 13, 2009 9:55 am     Reply with quote
Thanks, that's what it was!
I just used the project wizard to start with and it added the fuse by default.
