LukeD Guest
Strange ">=" problem |
Posted: Sat Jan 10, 2009 11:56 am |
Hello!
I'm working on a simple fading example, to test PWM... but I noticed a strange problem in the fade_down() sub.
The for loop never ends:
Code: | for(step = max_duty; step >= 0; step--) { |
The only way I can stop it at the correct value is change to:
Code: | for(step = max_duty; step != -1L; step--) { |
Maybe it's a stupid mistake but I can't find it...
Thanks!
#include "main.h"
#include <string.h>
#define PR2 20
#define BUFFER_SIZE 10
#define CR 0x0d
#define LF 0x0a
#define STEP_DELAY 30
char help_cmd[5] = "?";
char fadeup_cmd[10] = "FADEUP";
char fadedown_cmd[10] = "FADEDOWN";
char fadex_cmd[10] = "FADEX";
long max_duty;
char input_buffer[BUFFER_SIZE];
int input_index;
int1 input_ok;
long step;
#INT_RDA
void rs232_isr(void) {
char temp;
temp = getc();
if (temp == CR) {
input_buffer[input_index] = '\0';
input_ok = true;
printf("\r\n");
return;
if (temp == LF) return;
putc(temp);
input_buffer[input_index] = toupper(temp);
if (input_index >= (BUFFER_SIZE - 1)) input_index = 0;
else input_index++;
void fade_up() {
setup_timer_2(T2_DIV_BY_1, PR2, 1);
set_pwm1_duty(0);
printf(" Start fading up...\r\n");
setup_ccp1(CCP_PWM);
for(step = 0; step <= max_duty; step++) {
printf("%Ld\t", step);
set_pwm1_duty(step);
delay_ms(STEP_DELAY);
printf(" ...done!\r\n");
void fade_down() {
set_pwm1_duty(max_duty);
printf(" Start fading down...\r\n");
void usage() {
printf(" Available commands:\r\n");
printf(" FADEUP - start fading up\r\n");
printf(" FADEDOWN - start fading down\r\n");
printf(" FADEX - start cross fading\r\n");
void decode_command() {
if (strcmp(input_buffer, fadeup_cmd)==0)
fade_up();
else if (strcmp(input_buffer, fadedown_cmd)==0)
fade_down();
else if (strcmp(input_buffer, fadex_cmd)==0) {
fade_up();
fade_down();
else if (strcmp(input_buffer, help_cmd)==0)
usage();
else printf(" Unknown command: %s\r\n", input_buffer);
void main() {
setup_ccp1(CCP_OFF);
max_duty = 4 * (PR2 + 1);
input_ok = False;
input_index = 0;
disable_interrupts(GLOBAL);
enable_interrupts(INT_RDA);
printf("> ");
while(1) {
if(input_ok) {
input_ok = False;
decode_command();
printf("> ");
input_index = 0;
Posted: Sat Jan 10, 2009 12:55 pm |
In CCS, all integer data types are unsigned by default. An unsigned
integer can never be less than 0. To make 'step' into a signed value,
you need to declare like this:
LukeD Guest
Posted: Sun Jan 11, 2009 2:03 pm |
thanks and sorry for the dumb question |
