Bootloader for loading External Memory (18F8722)
nmeyer
PostPosted: Fri Jan 09, 2009 9:21 am     Reply with quote
I have posted some other posts about the PIC18F8722 and extended memory. I have been having issues with this, but through seaching the forum and some support from CCS I have made some progress. However, now I feel I understand what i have to do, but i am having issues. I was trying to load the program into external memory with the ICD, but support from CCS informed me that is not possible for the ICD. So the suggestion was to use a bootloader. Which I have takedn the CCS bootloader and i have been trying to modify it to work so that it will bootload the PIC flash first and then switch over to the external flash. I am prototyping this on the 18F8722 demo board from CCS. CCS's suggestion was to modify the bootload code so that in the areas which it call for write_program_memory() i needed to add in a decision point to determine whether it was internal memory or external and then add in wirite functions for the external. I have done this using the at1029.c include file for the write_ext_flash_memory() functions. All portions of this program seem to work fine seperately, bootloader, writing to external flash and main program. However, when i try to fully implement this with the switch over between internal and external my bootloader then hangs and times out. I am not sure why.
I have a new device called 18F8722EX that has 131072 for memory and a new 18F8722EX.h file that has the device called out as 18F8722EX.
Here is my Bootloader_ex.c
#if defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)  // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#include <18F8722EX.h>
#FUSES WDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
//#FUSES NOBROWNOUT               //No brownout reset
#FUSES BROWNOUT                  //BROWN OUT ON
#FUSES BORV27                    //RESET VOLTAGE AT 2.7V
//#FUSES BORV42                    //RESET VOLTAGE AT 4.2V
//#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOPUT                    //No Power Up Timer
//#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
//#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode enabled
#FUSES EMCU
#FUSES ABW20
#FUSES BW16
#use delay(clock=20000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,RESTART_WDT,ERRORS)
#endif
#define _bootloader
//#include <bootloader.h>
//#include <loader.c>
#include "Z:\Projects\132-Rawson\07-012 AccurateII\Code\Extended Memory\bootloader.h"
#include "Z:\Projects\132-Rawson\07-012 AccurateII\Code\Extended Memory\loader_ext.c"
 #org LOADER_END+1,LOADER_END+10
 #org LOADER_END+2,LOADER_END+20
#endif
void application(void) {
  while(TRUE);
#if defined(__PCH__)
#org 0x40,0x7F
#else
#org 0x20,0x3F
#endif
void main(void) {
   if(!input(PIN_A4))
      load_program();
   application();
#ORG default
#int_global
void isr(void) {
   jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
minor adjustments to CCS bootloaer.c
This is the loader_ext.c i have modified this to have the decision point for internal and external.
#ifndef LOADER_END
#define LOADER_END      getenv("PROGRAM_MEMORY")-1
   #define LOADER_SIZE   0x17F
   #define LOADER_SIZE   0x3FF
#endif
#endif
#include "Z:\Projects\132-Rawson\07-012 AccurateII\Code\Extended Memory\ext_flash.c"
#define LOADER_ADDR LOADER_END-LOADER_SIZE
#define BUFFER_LEN_LOD 64
int  buffidx;
char buffer[BUFFER_LEN_LOD];
#define ACKLOD 0x06
#define XON    0x11
#define XOFF   0x13
#SEPARATE
unsigned int atoi_b16(char *s);
#ORG LOADER_ADDR+10, LOADER_END auto=0 default
void real_load_program (void)
   int1  do_ACKLOD, done=FALSE;
   int8  checksum, line_type;
   int16 l_addr,h_addr=0;
   int32 addr;
   #if getenv("FLASH_ERASE_SIZE")>2
      int32 next_addr;
   #endif
   int8  dataidx, i, count;
   int8  data[32];
   init_ext_flash_memory();
   while (!done)  // Loop until the entire program is downloaded
      buffidx = 0;  // Read into the buffer until 0x0D ('\r') is received or the buffer is full
      do {
         buffer[buffidx] = getc();
      } while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
      putchar (XOFF);  // Suspend sender
      do_ACKLOD = TRUE;
      // Only process data blocks that start with ':'
      if (buffer[0] == ':') {
         count = atoi_b16 (&buffer[1]);  // Get the number of bytes from the buffer
         // Get the lower 16 bits of address
         l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
         line_type = atoi_b16 (&buffer[7]);
         addr = make32(h_addr,l_addr);
         #if defined(__PCM__)  // PIC16 uses word addresses
            addr /= 2;
         #endif
         // If the line type is 1, then data is done being sent
         if (line_type == 1) {
            done = TRUE;
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000){
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000){
         #endif
            checksum = 0;  // Sum the bytes to find the check sum value
            for (i=1; i<(buffidx-3); i+=2)
               checksum += atoi_b16 (&buffer[i]);
            checksum = 0xFF - checksum + 1;
            if (checksum != atoi_b16 (&buffer[buffidx-3]))
               do_ACKLOD = FALSE;
            else   {
               if (line_type == 0) {
                  // Loops through all of the data and stores it in data
                  // The last 2 bytes are the check sum, hence buffidx-3
                  for (i = 9,dataidx=0; i < buffidx-3; i += 2)
                     data[dataidx++]=atoi_b16(&buffer[i]);
                  #if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
                     #else
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
                     #endif
                           erase_program_eeprom(addr);
                     next_addr = addr + 1;
                  #endif
                  if (addr<=0x1FFFF)//this is my modification
                     write_program_memory(addr, data, count);
                     write_ext_flash_memory(addr-0x20000, data, count);//to here
               else if (line_type == 4)
                  h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
      if (do_ACKLOD)
         putchar (ACKLOD);
      putchar(XON);
   putchar (ACKLOD);
   putchar(XON);
   #ifndef _bootloader
   reset_cpu();
   #endif
unsigned int atoi_b16(char *s) {  // Convert two hex characters to a int8
   unsigned int result = 0;
   int i;
   for (i=0; i<2; i++,s++)  {
      if (*s >= 'A')
         result = 16*result + (*s) - 'A' + 10;
         result = 16*result + (*s) - '0';
   return(result);
#ORG default
#ORG LOADER_ADDR, LOADER_ADDR+9
void load_program(void)
   real_load_program();
the ext_flash.c is the same as at29C1024.c file included with the compiler except for this change
void write_ext_flash_memory(long address,long value, long count)
     write_external_memory(START_ADDRESS+((int32)2*address),&value,count);
     while(read_ext_flash_memory(address)!=value);
Does any one see any reason why my decision point is causing it to time out?
