help! cdc example - 18f2450 problem.
jaikumar
PostPosted: Wed Dec 24, 2008 2:00 am     Reply with quote
What do I have to modify to make cdc example work in 18F2450 ?
The chip is able to send data but not receiving data.
Example works with 18F2550.
do {
      usb_task();
      if (usb_enumerated()) {
         printf(usb_cdc_putc, "\r\nHello World !");
         RcvUSB = usb_cdc_getc(); !!!!THIS IS NOT WORKING!!!!
         if (RcvUSB=='b') {
            printf(usb_cdc_putc, "\r\nSee how I blink 20 times on Port A.0 !");
            for (i=1;i<=20;i++) {
               output_bit( PIN_B0, 1);
               delay_ms(250);
               output_bit( PIN_B0, 0);
               delay_ms(250);
            printf(usb_cdc_putc, "\r\nI just received : %c",RcvUSB);
   } while (TRUE);
Thanks and regards,
Jai.
PostPosted: Wed Dec 24, 2008 2:49 am     Reply with quote
Did you also examine the CCS provided CDC examples? Generally, they use a construct like this:
if (usb_cdc_kbhit()) {
  c=usb_cdc_getc();
If you call usb_cdc_getc() without a character available, the program will wait for a character, pausing service of the USB interface. This may cause the host to suspend the device.
As another point, I experienced a problem with the CCS USB driver, that apparently failed to reenable global interrupts in some situation. I didn't further investigate the issue, but added an additional reenable at the end of the main loop:
It can't do any harm, cause global interrupts are enabled at that program level anyway, but effectively removed my problem.
Best regards and Merry Christmas
Frank
capnmattttt
PostPosted: Mon Jan 05, 2009 11:06 pm     Reply with quote
I am having a similar problem with the 18F2450. I can send characters from the PIC, but I don't seem to receive characters.
Here is my code.
#include <18F2450.h>
#device adc=8
#fuses ECPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL1,CPUDIV4,VREGEN
#use delay(clock=16000000)
#include <usb_cdc.h>
#define led1            pin_c6
#define led2            pin_c7
#define LED_ON          output_high
#define LED_OFF         output_low
int8 DATA_RX[1];
//int8 byte1;
void main(){
   //int8 i;
   LED_OFF(led1);
   LED_OFF(led2);
   usb_init();
   while (true) {
      if (usb_enumerated()){
         led_on(led1);
         if(usb_cdc_kbhit()){
            //for (i=0;i<31;++i){
            DATA_RX[0] = usb_cdc_getc();
            LED_ON(led2);
            Delay_ms(200);
            LED_OFF(led2);
            //for (i=0;i<32;++i){
            usb_cdc_putc(DATA_RX[0]);
            Delay_ms(200);
            LED_ON(led2);
            Delay_ms(200);
            LED_OFF(led2);
jaikumar
Give it up. Use the 18F2550.
PostPosted: Thu Jan 08, 2009 2:12 am     Reply with quote
My Advice,
Give it up. Don't waste time. The cdc uses about 65% of RAM and believe me
you need a lot of them.
I wonder even if the 18F2550 is Good enough for a bit large app. This cdc example and all other do work on 18F2550 so Change your chip.
Any way here in india we don't save too much money any way.
Regards,
Jai.
PostPosted: Thu Jan 08, 2009 2:54 am     Reply with quote
You're right, that RAM capacity is critical with PIC2450. I don't have it and can't check, if basic CDC is working there, but I suppose it does. The present code however can't work without an usb_task() call.
