EX_FREQC question....
aldinlapinig
PostPosted: Mon Aug 13, 2007 7:10 pm     Reply with quote
I've looked at the EX_FREQC example of CCS C compiler but I couldn't understand what pin is used as input of the frequency being measured. Anybody knows this? Thank you.
PostPosted: Mon Aug 13, 2007 7:34 pm     Reply with quote
The comments say this:
/// The input signal is to be supplied to pin C0
aldinlapinig
PostPosted: Tue Aug 14, 2007 8:52 am     Reply with quote
thank you PCM Programmer...I just couldn't understand how it configured pin C0 as output. I'm doing a project now that measures the frequency from 8 inputs. Can I use the same program to do this? How can I make the program to read the frequency from many different pins (like ports b4,b5,b6,b7, a1,a2,a3)? I'm sorry for asking too much but I'm running out of ideas. I'm an amature hobbyist. Thank you very much.
srikanth bodduna
EX_FREQC.C with pic16f873a
PostPosted: Sat Jan 10, 2009 1:49 am     Reply with quote
did anybody tried the EX_FREQC.C with pic16f873a if so please help me...what changes sholud be made to get the result.
PostPosted: Sat Jan 10, 2009 1:10 pm     Reply with quote
Ex_Freqc.c uses Timer1 with an External Input. The input is on pin C0.
Pin C0 is a Schmitt Trigger input pin. This means it requires input voltage
levels of 0v to 4v, when the PIC is running at 5v.
Your circuit only provides 2.3v input levels. So it will not work.
You neeed to fix this problem. Increase the input level so it goes
between 0v and 4v.
Until you do this, nothing will work.
