Tagge
PIC18F4550 i2c problem |
Posted: Fri Jan 09, 2009 9:23 am |
Hi, I have a problem with a non working i2c on my PIC.
It seems that I havent got a clock pulse on the scl pin?
Is there something that can interfere with this pin?
Im using the HW i2c on the uP. Compiler ver:4.068
Code: | #include <18F4550.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz
#FUSES BROWNOUT_NOSL //Brownout enabled during operation, disabled during SLEEP
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES PLL1 //No PLL PreScaler
#FUSES ICPRT //spec prog port
#use delay(clock=4000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,restart_wdt,errors)
#use i2c(MASTER, SDA=PIN_B0, SCL=PIN_B1, FORCE_HW) |
init sequence: only using timer0 at this time Code: |
void init(void)
SET_TRIS_A( 0xfF );
SET_TRIS_B( 0xa0 );//RB0,RB1 out
SET_TRIS_C( 0xa3 );//10100011 0xa3
SET_TRIS_D( 0xff );
SET_TRIS_E( 0x00 );
setup_adc_ports( NO_ANALOGS );
//setup_adc_ports(AN0_TO_AN4|VSS_VDD);
//setup_adc(ADC_CLOCK_INTERNAL);
//setup_psp(PSP_DISABLED);
//setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
//setup_spi(FALSE);
//setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16|RTCC_8_bit);
//setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
//setup_timer_2(T2_DISABLED,0,1);
///setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
//setup_comparator(NC_NC_NC_NC);
//setup_vref(FALSE);
//enable_interrupts(INT_RDA);
//enable_interrupts(INT_TBE);
//setup_low_volt_detect(FALSE);
//setup_oscillator(False);
And then I use the i2c by:
void get_temperature(SENSOR_ADDR)
i2c_start();
i2c_write(SENSOR_ADDR);
i2c_write(REG_0_TEMP);
i2c_start();
i2c_write(SENSOR_ADDR | READ_BIT);
bTempHi = i2c_read(ACK);
bTempLo = i2c_read(NO_ACK);
i2c_stop();
liTemp = MAKE16(bTempHi,bTempLo);
liTemp=(liTemp >> 7 );
fTemp = (float)liTemp*KTEMP;
But the code gets stuck already at "i2c_write(SENSOR_ADDR);"
When measering with an oscilloscope there is no sign of a scl puls?
And I do have a pull-up, 8k2 on the SDA pin.
Anyone got an idea?
Thanks |
Posted: Fri Jan 09, 2009 9:49 am |
First, you need pull-ups on both SCL, and SDA.
Second, you are enabling INT_TIMER0, but show no handler for this. Repeat after me, you _must_ have a handler present for any interrupt that is completely enabled. If you don't, this can hang the processor...
Third, have you got a pull-up on MCLR?. Otherwise the processor probably won't start, with MCLR enabled.
You don't need the TRIS statements. Let the compiler handle these for you.
Have you got a 4MHz external crystal attached?.
Tagge
Posted: Fri Jan 09, 2009 1:36 pm |
Hi and thanks, got it rolling by removing the set_tris() , altough I cant figure out whats wrong with them??
where can I make sure how the ports are configured now?
And, yes, the timer0 isr is handled, 1 sec clock. And working fine.
And, yes, I got a 4MHz crystal. And mclr is allways pulled-up!
Thanks again for the quick response, best forum on the web! ![Smile](images/smiles/icon_smile.gif) |
Posted: Fri Jan 09, 2009 4:25 pm |
If you look at table 10-3, and look at the settings for RB0, and RB1, you will find that RB0 and RB1, both need their TRIS bits set as 1 (input), to work with the I2C hardware. Setting it to '0', makes the pins into digital outputs, and override the I2C peripheral. Hence your TRIS settings are stopping I2C from working.
This is typical of the 'complexities' of TRIS settings on the PIC. They are easy, when dealing with simple I/O,, but not when dealing with the peripherals. You will (for example), find some older chips that on their serial pins do require the TRIS set for input on the receive, and output on the transmit pins, but other latter chips require the same peripheral to have the pins both set as inputs. Hence in general, it is much simpler to leave TRIS settings to the compiler, and only use them for specific 'overrides', where you have checked everything on the data sheet, or for the ultimate speed....
