WAV file format
tongbram
View user's profile Send private message AIM Address ICQ Number
WAV file format
PostPosted: Mon Jan 05, 2009 12:34 am     Reply with quote
hi..
i m doing a project on voice recording using PIC and i have to store the recorded sound on SD card in wav file format. The sampling frequency is 8000Hz and i m using 10bit ADC. The sampled data is converted into 2:1 ADPCM using microchip's code.
Now the problem is, i want to convert it into WAV file format and store in SD card. I have already used SD card for storing data in TXT format.
Can anybody help me.........
THANK IN ADVANCE...
manibabu
John P
PostPosted: Mon Jan 05, 2009 10:37 am     Reply with quote
Is this what you're looking for?
http://ccrma.stanford.edu/courses/422/projects/WaveFormat/
tongbram
PostPosted: Tue Jan 06, 2009 1:47 am     Reply with quote
Thanks i already visited that link....I know the Format of wave but i need source code for inserting Header particularly for PIC controller. i will appreciate if anybody share source code for similar project like this....
One think, can i implement a block of 100 byte in which 44 byte will be header and the rest 56 will be data. This is going to implement after every 56th sample right?. After implementing the block, the whole block is store in SD card in .WAV extension. My point is weather such file can be play using window media player.....i will be very thankful if anybody reply....
manibabu
magestik
Re: WAV file format
PostPosted: Tue Jan 06, 2009 2:43 am     Reply with quote
Hello, i'm also looking to do this, could you post your code ? Embarassed
Thanks Razz
tongbram
PostPosted: Tue Jan 06, 2009 4:54 am     Reply with quote
Actually i have did that part of the code using MikroC compiler. The compiler have example code on SD/MMC.
I have tried in CCS also but only for read/write in sector wise operation. Still trying using FAT in CCS.
manibabu
