asteriskme Guest
| serial communication continued |
Posted: Mon Jan 05, 2009 11:49 pm |
Thank you very much for your reply. I think i am confused when i am writing to the forum my code will be like this (coma and comb will reverse)
#include "16F877A.H"
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7,stream=coma)
#use rs232(baud=9600, xmit=PIN_B2,rcv=PIN_B3,stream=comb)
char c;
align=0;
while(TRUE){
if(align==0){
fprintf(comb,"sending search signal");
putc('~',coma);
align=0;
if(kbhit(coma)){
fprintf(comb,"received something");
c=getc(coma);
if(c=='~')
fprintf(comb,"received search signal");
else {
putc(c,comb);
I am using isis professional also for this code and for the other code that i wrote before it gives what i want.But in real world i cant make the same thing.i also abandoned writing sending search signal received something and received search signal.I just wrote the following code
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7,stream=coma,ERRORS)
char c;
align=0;
while(TRUE){
if(align==0){
putc('a',coma);
align=0;
if(kbhit(coma)){
c=getc(coma);
if(c=='~')
else {
putc(c,comb);
What i am trying to do is
I have both tx/rx in two side so nodes will send '~' or 'a' for search signal if a node gets search signal it responds back hey i got something and if he gets '~' he will say i got search signal.
I will try to send just '~' not comments at all but in future that will not help because i have to set some flags and preambles for the protocols. So if pic16f877a have hardware limitations to do this i will use another pic what you prefer me? |
Posted: Tue Jan 06, 2009 1:43 pm |
Please don't start a new thread every day on the same topic. Make a
new post in your existing thread, here:
http://www.ccsinfo.com/forum/viewtopic.php?t=37252
When you do so, the thread will be "bumped" to the top of the list.
Also, forum members that are logged in will see a yellow box to the
side of your thread, indicating a new post. You don't see that as a
guest. We will all see your new post. |
