Debugging / watch Problem in MPLAB on CCS compiler
Nandus2000
PostPosted: Thu Jan 15, 2009 11:46 am     Reply with quote
I'm using MPLAB (Ver. 8.14) & ICD2 with CCS C compiler (Ver 4.076) for PIC16F883 development.
During the debugging, I need to watch contents / value of one of the global variable of type long int.
It displays the value of that global variable as "Reserved Memory" in the watch window of MPLAB IDE.
Pls. can anyone let me know what would be the reason?
Your timely correct help will be highly appreciated.
Thanks,
Nandu
PostPosted: Thu Jan 15, 2009 1:16 pm     Reply with quote
Post a very short test program that shows the problem. (10 lines, max).
