A #DEVICE required before this line
Jhon
PostPosted: Fri Jan 02, 2009 8:53 am     Reply with quote
Dear Sir,
I am just started using PCWHD CCS C compiler with IDE. My project is multifile project based on PIC16F873.
When i have compiled it shows with an error: Executing: "C:\Program files\Picc\CCSC.exe" +FM "Telephone01.c" +DF +LN +T +A +M +Z +Y=9 +EA *** Error 128 "C:\Documents and Settings\Admin\Desktop\TRY\pic1687x.h" Line 19(1,2): A #DEVICE required before this line 1 Errors, 0 Warnings.
Halting build on first failure as requested.
When i double clicked on this line it takes the cursor to a extern definition of a variable in. Before those code below,
* Header file for the Microchip
* PIC 16F870
* PIC 16F871
* PIC 16F872 chip
* PIC 16F873 chip
* PIC 16F874 chip
* PIC 16F876 chip
* PIC 16F877 chip
* Midrange Microcontroller
#if defined(_16F874) || defined(_16F877) || defined(_16F871)
#define __PINS_40
#endif
(error happen here)
static volatile unsigned char INDF @ 0x00;
static volatile unsigned char TMR0 @ 0x01;
static volatile unsigned char PCL @ 0x02;
static volatile unsigned char STATUS @ 0x03;
static unsigned char FSR @ 0x04;
static volatile unsigned char PORTA @ 0x05;
static volatile unsigned char PORTB @ 0x06;
static volatile unsigned char PORTC @ 0x07;
#ifdef __PINS_40
static volatile unsigned char PORTD @ 0x08;
static volatile unsigned char PORTE @ 0x09;
#endif
Why so happening??
I have try put #device PIC16F873 still fail.
Could anybody help me in this regard.
Thanks,
Jhon
PostPosted: Fri Jan 02, 2009 11:57 am     Reply with quote
This is Hi-Tech C code. Hi-Tech code doesn't compile in CCS.
Here are header files that have the SFR register declarations for CCS:
For 16F:
http://www.ccsinfo.com/forum/viewtopic.php?t=20186
http://www.ccsinfo.com/forum/viewtopic.php?t=20697
For 18F:
http://www.ccsinfo.com/forum/viewtopic.php?t=14755
