setup_timer0 and set_timer0 function problem for ccs compile
PostPosted: Fri Dec 19, 2008 9:31 pm     Reply with quote
Hi All,
I have been trying to use timer0 as arbitrary timer to generate different delay.
I created a function as below:
int delay(int16 timer_val, int8 prescaler) {
setup_timer_0(RTCC_INTERNAL|prescaler);  //!setup timer0
clear_interrupt(INT_RTCC);
enable_interrupts(INT_RTCC);
set_timer0(timer_val);
Function call:
delay(0x7d0,RTCC_DIV_1);
and it didn't work; the timer interrupt never fires.
Then I tried timer_val as int32 and it didn't work either.
But I do function without any parameter passing and it works, and interrupt fires.
void delay() {
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);  //!setup timer0
set_timer0(0x7D0);
Is it CCS compiler problem or am I doing something wrong?
Thanks in advance.
Regards:
nehal
PostPosted: Sat Dec 20, 2008 1:59 am     Reply with quote
1. Post your PIC.
2. Post your compiler version.
Charlie U
PostPosted: Sat Dec 20, 2008 5:29 pm     Reply with quote
This problem has been stumbled over before. Check out the following post and see if it applies:
http://www.ccsinfo.com/forum/viewtopic.php?t=34095&highlight=
