change pins TX/RX
pvol
change pins TX/RX
PostPosted: Sat Dec 20, 2008 3:04 am     Reply with quote
Hello everybody
I wonder if I could change pins of tx/rx on 18f4620.
For example:
#use RS232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
change to
#use RS232(baud=9600, xmit=PIN_A0, rcv=PIN_A1)
Is it possible to do this?
Will it work?
vijay s
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sat Dec 20, 2008 4:36 am     Reply with quote
To make this PIN work as UART you have to use FORCE_SW in #use rs232.
it will generate software UART routines for the specified Pin.
with regards
vijay s
dyeatman
PostPosted: Sat Dec 20, 2008 7:56 am     Reply with quote
The hardware UART cannot be moved from C6/C7. If you change either one of those pins (or even if you swap TX and RX) in the USE RS232 command line, the compiler will automatically generate a software UART and the hardware UART will be disabled. It should not be necessary to use the FORCE_SW switch in the command line.
One word of caution. Using a sofware UART could be a problem if you are usings any non-UART interrupts. An interrupt from an ADC, for example, can interfere with a software UART and affect transmission or reception.
asmboy
perhaps a razor knife and rework wire is the answer
PostPosted: Sat Dec 20, 2008 9:41 am     Reply with quote
if this question was generated because of a PCB layout error
the real solution is a razor knife - and some Kynar or fine teflon rework wiring to get the correct wiring to the hardware UART - the hardware uart is your friend in all circumstances - the software uart is strictly for the desperate. Very Happy
