ADC does not work after PIC18F4520 to PIC18F4620 upgrade
madcat
PostPosted: Tue Dec 16, 2008 5:30 pm     Reply with quote
Hi to all,
I've used an 4520 to develop my software & hardware until 4620 arrived.
I had a perfectly working ADC routines.
I use MPLAB 8.1 as my IDE, ICD2 as debugger and CCS v4.068 compiler
After I've got the 4620 I replaced the chip and changed the include to <18F4620.h> (+ selected 4620 as target.)
I don't see any other changes I have to make. Both have AN0 on pin#2
128x64 LCD works fine, PWM controls the backlight fine. ADC reads a constant 0 (zero) output out of my light sensor at AN0
If I switch back to 4520 - it works fine.
My ADC init code is :
setup_adc_ports(AN0);
set_adc_channel(0);
Then :    light_lvl = read_adc();  inside the loop to read the sensor
Any ideas on what may be different on the 4620 compared to 4520 in relation to ADC ?
PostPosted: Tue Dec 16, 2008 5:39 pm     Reply with quote
Post a test program for your 18F4620 code, similar to this:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
Run it, verify that it fails, and post it.
madcat
PostPosted: Tue Dec 16, 2008 5:59 pm     Reply with quote
Here is my test program (simplified from the one that works with 4520)
I don't feel comfortable with the "itoa" but even when I watch the value of "light_lvl" in IDE it is zero.
If I change #device ADC=10 the value becomes "2" ...
#include <18F4620.h>
#device ADC=8
#device ICD=TRUE
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT, CCP2C1
#zero_ram
#use delay(clock=37188789)
#define FAST_GLCD
#include <HDM64GS12.h>
#include <graphics.h >
#include <stdlib.h>
   char txt[8];
   int16 light_lvl;
   // Setup Light Sensor
   set_adc_channel(0);
   // Init LCD
   glcd_init(ON);
   glcd_fillScreen(OFF);
   glcd_update();
   while(TRUE) {
        itoa(light_lvl, 10, txt);
        glcd_text57(20, 55,txt, 1, ON);
        glcd_update();
        delay_ms(40);
PostPosted: Tue Dec 16, 2008 6:32 pm     Reply with quote
Download the 18F4620 data sheet and look in this section:
19.3 Selecting the A/D Conversion Clock
TABLE 19-1: TAD vs. DEVICE OPERATING FREQUENCIES
Notice the maximum oscillator frequency restriction on using the
internal R/C oscillator for the ADC. You're running at almost 40 MHz.
The table gives two divisors that are more appropriate for that frequency.
Look in the 18F4620.H file (in the A/D section), to find the CCS constants
for those divisors. Use one of those constants instead of ADC_CLOCK_INTERNAL.
18F4620 Data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39626e.pdf
madcat
PostPosted: Tue Dec 16, 2008 6:47 pm     Reply with quote
The table says that 18F4620 at 40MHz needs TAD of 32 TOSC or 64 TOSC
from the .h file :
// Constants used for SETUP_ADC() are:
#define ADC_OFF               0           // ADC Off
#define ADC_CLOCK_DIV_2   0x100
#define ADC_CLOCK_DIV_4    0x04
#define ADC_CLOCK_DIV_8    0x01
#define ADC_CLOCK_DIV_16   0x05
#define ADC_CLOCK_DIV_32   0x02
#define ADC_CLOCK_DIV_64   0x06
#define ADC_CLOCK_INTERNAL 0x07           // Internal 2-6us
// The following may be OR'ed in with the above using |
#define ADC_TAD_MUL_0      0x00
#define ADC_TAD_MUL_2      0x08
#define ADC_TAD_MUL_4      0x10
#define ADC_TAD_MUL_6      0x18
#define ADC_TAD_MUL_8      0x20
#define ADC_TAD_MUL_12     0x28
#define ADC_TAD_MUL_16     0x30
#define ADC_TAD_MUL_20     0x38
I've tried both setup_adc(ADC_CLOCK_DIV_64) and setup_adc(ADC_CLOCK_DIV_32);
Both give ZERO :(
EDIT: also payed attention that this table is same for both 4520 and 4620.
4520 works even with ADC_CLOCK_INTERNAL ...
PostPosted: Tue Dec 16, 2008 6:53 pm     Reply with quote
Do you really have a crystal or oscillator that runs at that frequency ?
madcat
PostPosted: Tue Dec 16, 2008 7:08 pm     Reply with quote
Yes I do. Exactly at this frequency.
Also I've just tried the :
#fuses INTRC and setup_adc(ADC_CLOCK_INTERNAL);
That supposed to be at 31Khz ? gives ZERO as well .......
PostPosted: Tue Dec 16, 2008 7:25 pm     Reply with quote
I would make a test program that only uses RS-232 to display the output.
Use printf to display the "%LX" 16-bit adc result.
I would get rid of all the GLCD code, #zero_ram, etc., and also put in
a much larger loop delay, such as 500 ms.
madcat
PostPosted: Tue Dec 16, 2008 7:41 pm     Reply with quote
......I would get rid of ...... #zero_ram.....
THANK YOU ! Razz
It works and even in my original test program (with GLCD, PWM etc..)
and even with ADC_CLOCK_INTERNAL and 40 MHz Smile
I've just removed the #zero_ram .... WHY not with 4620 ?! bug ?
Interesting is that if I keep the #zero_ram and measure the actual voltage on the A0 pin it is really ZERO ! means it pulls it to ground. Do you have any idea why ?
madcat
PostPosted: Tue Dec 16, 2008 8:04 pm     Reply with quote
Found these 2 threads (4620) :
1. from 2004 (!) : the second poster says that he had to remove #zero_ram.
http://www.ccsinfo.com/forum/viewtopic.php?p=37454
2. from 2008 (unsolved) : the OP complains that A/D does not work...
http://www.ccsinfo.com/forum/viewtopic.php?t=34678
His program contains #zero_ram !
Looks like the #zero_ram clears on 4620 something that shouldn't be cleared... ?
