16F886 I/O
ccnewbie
16F886 I/O
PostPosted: Mon Dec 08, 2008 10:34 am     Reply with quote
I am truly a newbie. After discovered some notes at the examples and via forum, I tried some basic idea on getting the input.
#include <16F886.h>
#device ICD=1
#fuses INTRC,NOWDT, NOLVP, BORV21
#device *=16
#use delay(clock = 4000000)
#use rs232(xmit=PIN_C6, rcv=PIN_C7, baud=9600)
#include "em260.h"
#include "ember_utilities.c"
      set_tris_c (0xff);
   i++;
   c_rate[i] = PIN_C7;
I try to configure pin RC7 as my input (CCS Ember Zigbee kit only allow user interface at port C and analog at port A). I tried to read the serial input by looping and store it to c_rate. Then transmit it using ezspSendUnicast (). Correct me if I am wrong.
Smile
PostPosted: Mon Dec 08, 2008 10:57 am     Reply with quote
Download the CCS manual.
Look at the list of functions on page 141 (page 153 in the Acrobat reader).
Find the function that allows you to do input from a pin.
PostPosted: Mon Dec 08, 2008 11:41 am     Reply with quote
Thank you so much for the details ...
ccnewbie
PostPosted: Tue Dec 09, 2008 3:58 am     Reply with quote
How about if the input is a 3 decimal number from 7 segment display?
Due to the properties of 7 segment display, 7 bits are used to denote a character on the display. Is PIC 16F886 allows up to 8 bits of data input in a time? So that means if 3 characters needed, so an array for the
spi_read()
is required?
PostPosted: Wed Dec 10, 2008 1:04 am     Reply with quote
Yes it can be put in an array of 3 bytes. Or, 3 separate int8 variables
can hold the data. The Ember kit will have a function that you can call
to read data. But none of us have the Ember kit. I don't have it.
So we can only help you a little.
