leandroguida
Math problems |
Posted: Tue Dec 09, 2008 10:00 pm |
Hello there.
I'm doing a test code to calculate a period of time. Since I'm using a 4MHz crystal, my internal clock is 1Mhz giving me 1uS per cycle.
So here's my idea, if I can count the total cycles, I can get how many uS the process took.
So for this, I created the code below:
Code: | #include <16f877a.h>
#include <stdio.h>
#fuses HS, NOWDT, NOPROTECT, NOLVP
#use rs232(baud=9600, BITS=8, PARITY=N, STOP=1,x mit=PIN_C6, rcv=PIN_C7)
unsigned int16 tCcp = 0, tCcpAtual = 0;
unsigned int over = 0;
unsigned int32 tTotal, test;
volatile unsigned boolean ccpFlag = false;
#int_ccp1
void ccpH(){
tCcp = CCP_1;
ccpFlag = true;
#int_timer1
void timerHandler(){
over++;
void main(){
setup_ccp1(CCP_CAPTURE_RE);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
enable_interrupts(INT_CCP1);
while(true){
if(ccpFlag){
setup_ccp1(CCP_OFF);
setup_timer_1(T1_DISABLED);
tCcpAtual = tCcp;
test = (over*65535);
tTotal = test+tCcpAtual;
printf("Tempo Captura: \%ld\n\r",tTotal);
ccpFlag = false;
delay_us(100);
I'm using the PIC16F877A. I'm thinking like that: Since my timer is a 16bit one, when I have a overflow interrupt I'll have counted 65535 uS.
So I increment a 'over' variable to count how many overflow interrupts I had.
Then I get the CCP_1 which is the timer value when the CCP_1 event occurred.
My Total time would be:
Code: | tTotal = (over*65535)+tCcpAtual; |
Where tCcpAtual, as showed in the code, is the CCP_1.
I can't get the right 'over' total overflow time. When I use a normal number, it works. (Like, if I do 10*65535 I'll have 655350). But using the variable 'over', don't work.
What is the problem, is it my variable type ? Is the math instructions wrong?
serial exit is just as a feedback for me. |
Posted: Wed Dec 10, 2008 1:10 am |
The product of two int16 numbers is also int16. over*65535 is calculated as an int16 quantity, discarding the overflowing bits and then assigned to the int32 variable.
I think, that the multiply should be with 0x10000 or 65536 anyway, which reduces the multiply to a shift respectively assignment to high word, achievable e. g. by make32() CCS private function.
Using general C-syntax, a type cast would be the means to clarify your intentions, e. g. (int32)over*65535. |
leandroguida
Thanks... |
Posted: Wed Dec 10, 2008 5:15 am |
Thanks a lot. It worked! |
Posted: Wed Dec 10, 2008 9:24 am |
As a comment, FvM, is 'dead right', that you would handle this more correctly, and much quicker, using shifts, or make32.
One 'route', that is 'non obvious', if you are not used to C unions, and is very efficient indeed, is to use a union for this. So something like:
struct words {
low_word;
high_word;
union {
struct words w;
int32 whole;
} timer32;
Then in your overflow routine, just increment timer32.w.high_word. Copy your tCcp value into timer32.w.low_word, and the required result should be in timer32.whole.
No arithmetic involved.
Very much faster, and more compact.
