| t90
				| my list not work |
				|  Posted: Sun Dec 07, 2008 10:12 am |   |
				| I'm working with 18f4550. I implement the static_list via array 20 element that every element is a struct. Main method in my list is insert(); In this function I invoke 2 function bcopy() (I tested this function and this work well) and memcmp() (exist in CCS PIC C). But when I test values in this array, the values are not the values I had inserted in the array. Someone give me some solution.
  	  | Code: |  	  | #include "18f4550.h"
 #device HIGH_INTS=TRUE
 #fuses HS,NOPROTECT,NOLVP,NODEBUG,NOWDT
 #use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
 #include "ewl_glcd.c"
 #include "ewl_realtime.c"
 char glcd_buff[128];
 char xuat1[6];
 char xuat2[6];
 char xuat3[6];
 char xuat4[6];
 struct Node{
 int time[4];
 struct Node tim[20];
 static int num;
 static int header;
 static int tailer;
 static int index;
 static BYTE temp[4];
 void bcopy(int *a, int *b) // This function requires 2 pointers
 int i;
 for (i = 0; i < 4; i++)
 *b++ = *a++; // or *b++ = *a++; should work as well
 //them vao 1 phan tu
 int insert(int8 rtb[4]){
 int temp1[4];
 int temp2[4];
 int temp3;
 int count;
 int1 flag;
 count=0;
 flag=1;
 index=header;
 if(num==20)//is ovrload?
 return 0;//overflow
 if(num==0){//overlow
 //strcpy(tim[index].time,timt);
 bcopy(rtb,tim[index].time);
 tailer=index;
 num=1;//increase number of element
 return 1;//suc
 //less than header
 if(memcmp(tim[index].time,rtb,4)>0){
 if(index==0){
 index=19;
 }else
 index--;
 num++;
 header=index;
 return 1;
 while(flag){//find the location of the element that greater than rtb
 if(memcmp(tim[index].time,rtb,4)==0)//if equal
 return 2;//the array has this value,return
 else if(memcmp(tim[index].time,rtb,4)<0){//if less than
 count++;//count is increased
 if(count>num){//counter greater than the max number of element in this array
 tailer=index;
 num++;
 return 1;
 if(index==19)//simulate the cyclic buffer
 index=0;//index goback 0 when index reach the max index of array(19)
 index++;
 flag=0;
 count=num-count;
 bcopy(rtb,temp1);
 for(count;count>0;count--){//change values of element form index to tailer
 tailer=index;
 bcopy(tim[index].time,temp2);
 bcopy(temp1,tim[index].time);
 bcopy(temp1,temp2);
 if(index==19)
 index=0;
 index++;
 num++;
 return 1;
 int a1[4];
 int a2[4];
 int a3[4];
 int a4[4];
 int a5[4];
 int a6[4];
 int receive1;
 int receive2;
 int receive3;
 int cp1;
 int cp2;
 int cp3;
 num=0;
 header=0;
 tailer=0;
 temp[0]=0xFF;
 temp[1]=0xFF;
 temp[2]=0xFF;
 temp[3]=0xFF;
 a1[0]=0x00;
 a1[1]=0x00;
 a1[2]=0x00;
 a1[3]=0x00;
 a2[0]=0x01;
 a2[1]=0x01;
 a2[2]=0x01;
 a2[3]=0x01;
 a3[0]=0x02;
 a3[1]=0x02;
 a3[2]=0x02;
 a3[3]=0x02;
 a4[0]=0x03;
 a4[1]=0x03;
 a4[2]=0x03;
 a4[3]=0x03;
 receive1=insert(a1);
 receive2=insert(a2);
 receive3=insert(a3);
 receive=insert(a3);
 set_time();
 set_tris_e(0x00);
 set_tris_d(0x00);
 set_tris_b(0xfc);
 set_tris_c(0b10000000);
 set_tris_a(0x00);
 glcd_init(ON);
 glcd_fillScreen(OFF);
 //glcd_text57_Vn(0,0,text,1,1);
 //set up LCD
 set_tris_c(get_tris_c()&0b11111011);
 init_DS1307();
 sprintf(xuat1,"%u-%u-%u-%u\n",tim[3].time[0],tim[3].time[1],tim[3].time[2],tim[3].time[3]);
 sprintf(xuat3,"%u-%u-%u-%u\n",tim[4].time[0],tim[4].time[1],tim[4].time[2],tim[4].time[3]);
 sprintf(xuat4,"%u-%u-%u-%u\n",tim[5].time[0],tim[5].time[1],tim[5].time[2],tim[5].time[3]);
 while(1){
 glcd_text57(20,20,xuat1,1,ON);//display element of the list
 glcd_text57(20,30,xuat3,1,ON);
 glcd_text57(20,40,xuat4,1,ON);
