kd5uzz_ Guest
Timer1 help - 500ms ISR for Timer1 on 16F688 |
Posted: Fri Dec 05, 2008 4:55 pm |
I've never used Timer1 before, I always use Timer2 for my LEDs, etc. This time I'm using a 16F688 and it doesn't support Timer2.
I'm using the internal clock @ 8mhz.
I need to check a pin every 500ms.
8,000,000/4 = 2,000,000 -> clock ticks
2,000,000/8 = 250,000 ticks per ISR
250,000 ticks = 5ms (1000/250,000) right?
So that means I've got to have a counter that counts 100 ISRs. Any better way to do it? |
kd5uzz_ Guest
Posted: Fri Dec 05, 2008 4:57 pm |
Oh yeah..
Code: | #include <16F688.h>
#fuses NOWDT,NOPROTECT,NOBROWNOUT, NOMCLR, INTRC
#use delay(clock=8000000)
#use rs232(stream=Jech_Bus, baud=19200, xmit=PIN_C4, rcv=PIN_C5) |
Posted: Fri Dec 05, 2008 5:35 pm |
It's a 16-bit counter. It can count from 0 to 65535. If you use a
pre-scaler of 8, the timer clock is 250,000 Hz. It takes that many clocks
to count up 1 second. To count for a 1/2 second, it takes half that many
clocks: 125,000. The timer can do that in two interrupts, at 62,500
clocks each. |
