enum with 16-bit values
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Fri Dec 05, 2008 1:30 am     Reply with quote
Colleagues,
I have a quick question (unfortunately, I couldn't find the answer in online help). Can enum have 16-bit values? I've tried enum {C = 0xFFFF}; and it compiled, however I still want to check with the community.
Thanks,
- Nick
Read the label, before opening a can of worms.
PostPosted: Fri Dec 05, 2008 1:35 am     Reply with quote
I don't know, but would take a look at the code, the expression compiles to.
kender
PostPosted: Fri Dec 05, 2008 1:50 am     Reply with quote
FvM wrote:
... look at the code, the expression compiles to.
None of my enums (including the 8-bit ones that have been proven to work), consts and #defines show ASM code next to them in the C/ASM listing.
PostPosted: Fri Dec 05, 2008 3:31 am     Reply with quote
No, the code will be where you use it.
 enum test {C = 0xFFFF};
 test val;
 int16 dummy;
 dummy=(int16)test;
If you look at the list, and the sym file, you will find that 'val', is declared using 16bits, and two bytes are copied:
....................  dummy=(int16)val;
0031:  MOVF   22,W
0032:  MOVWF  24
0033:  MOVF   21,W
0034:  MOVWF  23
So, yes.
