#fuses in MPLAB / CCS
robin171
PostPosted: Fri Dec 05, 2008 4:56 am     Reply with quote
I work with MPLAB with CCS plugin. After compiling the configuration bits in MPLAB are different from the fuses I have set in code. My config:
#FUSES WDT128
#FUSES WDT
#FUSES HS
#FUSES NOPROTECT
#FUSES BROWNOUT
#FUSES BORV45
#FUSES PUT
#FUSES NOCPD
#FUSES STVREN
#FUSES DEBUG
#FUSES NOLVP
#FUSES NOWRT
#FUSES NOWRTD
#FUSES IESO
#FUSES FCMEN
#FUSES NOPBADEN
#FUSES NOWRTC
#FUSES NOWRTB
#FUSES NOEBTR
#FUSES NOEBTRB
#FUSES NOCPB
#FUSES LPT1OSC
#FUSES NOMCLR
#FUSES XINST
The configuration bits in MPLAB are:
oscillator: HS
fail-safe clock monitor: enabled
internal external switch over: enabled
power up timer: disabled
brownout detect: disabled in hardware
brownout voltage: 4,5V
watchdog timer: disabled - controlled by SWDTEN bit
watchdog postscaler: 1:128
CCP2-mux: RC1
PORTB A/D enable: digital I/O
Stack overflow reset: disabled
LVP: disabled
Extended instr set enable bit: disabled
When I change the brownout reset voltage... the MPLAB config bits also change, but when I change brown-out detect... nothing happens
What is wrong?
- Am I doing something wrong?
- MPLAB
- CCS
Kind regards,
Robin
PostPosted: Fri Dec 05, 2008 11:50 am     Reply with quote
#FUSES XINST
That's wrong. Always use NOXINST. The extended instruction set is
not supported by CCS.
For the rest of your problem:
1. Post your MPLAB version.
2. Post the CCS compiler version.
3. Post your PIC.
4. Post the programmer or debugger that you have selected in MPLAB.
5. Post if the code is actually compiling successfully. Does it say
"BUILD SUCCEEDED" in the MPLAB output window ?
6. Look in the Configure/Select Device menu in MPLAB. Do you have
your specific PIC selected ?
