yet another bootloader question for pic 18
Ramey
PostPosted: Fri Dec 05, 2008 2:39 am     Reply with quote
I'm tweaking my bootloader for a new project and I'm have some questions about the two interrupts.
In my boot loader I'm using #int_usb while in my application I'm polling a usb port - without out using interrupts. In the application I have the high priority interruput assigned to a more time critical task.
I use code in the boot loader below to redirect interrupts to the application unless a special button - the program load button - is pressed when things are powered up.
I'm unsure about the 0xA0. The interrupt tables are made by the CCS compiler. Is the "build" below sufficient or do I need two tables. If so, what syntax do I use to specify them?
Anyone who wants to chime in here - feel free.
Robert Ramey
#build(reset=0, interrupt=0xA0)
#org 0x0008,0x0037
void isr_global(){
    if(!in_app)
        jump_to_isr(0x00A0);
    jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
#org 0x0008,0x0017
void isr_global_hp(){
    #asm
    movf    in_app, w
    bz      0xa0
    goto    0x1808
    #endasm
#org 0x0018,0x0027
void isr_global_lp(){
    #asm
    movf    in_app, w
    bz      0xa0
    goto    0x1818
    #endasm
#org default
#inline
void fork(){
    if(input(NOTBOOTLOADER)){
        in_app = TRUE;
        goto_address(LOADER_END + 1);
        in_app = FALSE;
