UART and GPS
uni_student
View user's profile Send private message Send e-mail MSN Messenger
UART and GPS
PostPosted: Sun Dec 07, 2008 2:23 pm     Reply with quote
Hi, trying to display GPS data on an LCD that start with"$P" or "$G" and all others discarded. For some reason I am still displaying other data such as"$F" and "$ ". GPS is working fine and LCD working fine , but somewhere in the code I am going wrong! Help appreciated, Cheers.
#include <18f452.h>
#include <string.h>
#fuses HS,NOLVP,NOWDT
#use delay (clock=20000000)
#use rs232 (baud=4800, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, ERRORS)
//Misc defines
#define GREEN_LED PIN_E2
//LCD defines
#define D0_LCD PIN_B0
#define D1_LCD PIN_B1
#define D2_LCD PIN_B2
#define D3_LCD PIN_B3
#define D4_LCD PIN_B4
#define D5_LCD PIN_B5
#define D6_LCD PIN_B6
#define D7_LCD PIN_B7
#define EN_LCD PIN_D6
#define RS_LCD PIN_D7
#define RW_LCD PIN_D5
#define TOP_LINE 0x80
#define BOTT_LINE 0xC0
#define CLEAR_DISP 0x01
#define RETURN_HOME 0x02
void LCD_INIT (int x);
void DATA_MANIP (unsigned int x);
void LCD_INIT (int x){
void DATA_MANIP (unsigned int x){
    output_high (EN_LCD);
    output_bit ( D0_LCD, x & 0x01 );
    output_bit ( D1_LCD, x & 0x02 );
    output_bit ( D2_LCD, x & 0x04 );
    output_bit ( D3_LCD, x & 0x08 );
    output_bit ( D4_LCD, x & 0x10 );
    output_bit ( D5_LCD, x & 0x20 );
    output_bit ( D6_LCD, x & 0x40 );
    output_bit ( D7_LCD, x & 0x80 );
    output_low (EN_LCD);
void main (void){
   char r;
   int x, y;
   LCD_INIT (0);   //
   x=0;
   y=0;
   while(TRUE){
       r=getc();
       if ((x>0)&&(x<15)){   //Display charactors to end of lcd display
         x++;
         DATA_MANIP (r);
       } else if (x==15){    //End of display line
         delay_ms(2000);
         x=0;
         if(y==0){
            LCD_INIT (2); //Bottom Line
            y=1;
         } else{
            LCD_INIT (1); //Top Line
            y=0;
       } else if ((r=='$')&&(x==0)){  //start of new gps data
         r=getc();
         if (r=='G') {
            DATA_MANIP ('$');
            DATA_MANIP ('G');
            x++;
         if (r=='P'){
            DATA_MANIP ('$');
            DATA_MANIP ('P');
            x++;
       } else{
         x=0;
PostPosted: Sun Dec 07, 2008 2:38 pm     Reply with quote
Post the manufacturer and part number of your LCD.
uni_student
PostPosted: Sun Dec 07, 2008 2:48 pm     Reply with quote
Unsure of manufacturer of LCD (will check when home from work), but has Hitachi HD44780 driver in it. 16x2 LCD display, got it from futurlec.com.
PostPosted: Sun Dec 07, 2008 2:51 pm     Reply with quote
My suggestion is to use the flex LCD driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
Then you can call lcd_putc() to display a character, or use printf
to display a string (and re-direct the output of printf to lcd_putc).
It's much easier than your method.
PostPosted: Sun Dec 07, 2008 4:28 pm     Reply with quote
Although the code has long-winded actions, as the port B single bit output, it most likely doesn't keep the required timing according to HD44780 spec. With a parallel interface, it's easy to check the busy flag before writing to the display.
The single bit output can be replaced by a simple output_b(x);
