Wake up a node on CCS Ember board
ttbuddy
PostPosted: Wed Dec 03, 2008 10:19 am     Reply with quote
At the base station defined as the network coordinator,
EmberFormNetwork();
Status=ezspPermitJoining(0xFF);
By allowing the node to join the network, does it means the PIC 16F886 has been wake up from the sleep mode by the EZSP_NWAKE from the EM260 of the sensor board and query pin C7 for the input (Power button pushed to ON) for a time defined by emberPermitJoining()?
If lets say node A relay message to node B, so at A:
ezspJoinNetwork(EMBER_ROUTER)
emberPermitJoining(0x1E) /set to 30 secs for joinning
sleep()
After that I let node A enter the sleep mode.
Is my concept correct?
Does anyone doing coding like this before?
Appending the message frm node A to node B?
Thanks in advance.
evios
PostPosted: Thu Dec 04, 2008 5:17 am     Reply with quote
Does anyone know is the PIC wake up during network forming or when it is called by the #define?
