help pwm !!!!! control step pwm
smash
PostPosted: Tue Dec 02, 2008 3:54 am     Reply with quote
I'm having problems using the PWM of my PIC16F877. I want to change pwm using delay time such as from set_pwm1_duty(100) to set_pwm1_duty(200), and change it in single steps using delay_ms(50) +1 delay_ms(50) +1 from 100 +1 delay 50ms -->101 +1 delay 50ms --->102 +1 delay 50ms ---->....... to 200 and 200----->100 pwm
Help me
#include <16F877.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
int c2,D2;
int16 value;
float c;
   setup_timer_2(T2_DIV_BY_1,249,1); //20 khz
   setup_ccp1(CCP_PWM);
   setup_ccp2(CCP_PWM);
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_32);
while(true)
   set_adc_channel(0);
   delay_us(30);
   value=read_adc(); //read adc
   c = (float)(value * 5)/1023.0;
   c2 = c*10; // max value 50
    if(c2>=10)
        output_high(PIN_B1);
        output_low(PIN_B0);
        D2=c2*2;// value = 100
        set_pwm1_duty(D2);
    else if(c2>=0)
        output_low(PIN_B0);
        D2=c2*4; // value = 200
        set_pwm1_duty(D2);
Wayne_
PostPosted: Tue Dec 02, 2008 4:20 am     Reply with quote
If you want to continue monitoring the input while altering the PWM then something like this may do.
int speed = 100;
while(true)
  set_adc_channel(0);
  delay_us(30);
  value=read_adc();//read adc
  c2= c*10;// max value 50
  if(c2>=10)
  else if(c2>=0)
    D2=c2*4;// value = 200
  output_low(PIN_B0);
  if (speed < D2)
    speed++;
  else if (speed > D2)
    speed--;
  set_pwm1_duty(speed);
  delay_ms(50);  // this will slow your response input response time down, there are other options if this is a problem!
